Chibios and emBlocks Nightmare!
hakko
Post by hakko »
Hello! I have been trying to port chibios 3.0.4 to emblocks but without any luck... What I have been doing is to not use direct the make files on the project and use the ide based make instead.
But sorry to say this... Chibios file organization it's a bit messy! Lot of .mk files and a segmented linker script :? . Why not to put all files related to port a single chip in one folder? I had made work chibios 2.7.6 on my target device it's a bit messy (but it works fine) too but it does not have that assembly files that 3.0.4 does... I spend one day just to discover why the assembly files give me a lot of errors! Just because it does not a file extension with a capital "S". :roll: I have tried to use the C equivalent files from the old 2.7.6 on 3.x but also unlucky... Sorry but if you want to make your project more universal please forgot assembly startup and other stuff at least for cortex Mx parts that does not need any line of assembly code btw (I know that emblocks also like to make startup asm files but I use get ride of it and make a C one). I will not post my project here because now it is a big messy messy if some one have a project template(with the necessary files) with emblocks for stm32f429 or any other stm32 I will be very thankfull! And please don't take my words as a bad thing I only wants to make this project better! And you can ask me at the end... Why don't you use our eclipse based ide? Because I alredy have around 7 ecilpse based ide's installed on my pc and I don't want more one!
Re: Chibios and emBlocks Nightmare!
This person has ported the OS on em:blocks, you may ask for the template project.
viewtopic.php?f=16&t=3075&p=23770&hilit=emblocks#p23770
You can use ChibiOS on any properly configured Eclipse environment.
zhu
Post by zhu »
here the template file:
EmBitz_ChibiOS_stm32_blink_template.zip
(12.97 KiB) Downloaded 256 times
detailed steps:
Startup files.
reference:
$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/mk/startup_stm32f1xx.mk
source files:
$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/crt1.c
$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/vectors.c
$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/crt0_v7m.s
include folders:
$(CHIBIOS)/os/common/ports/ARMCMx/devices/STM32F1xx
$(CHIBIOS)/os/ext/CMSIS/include
$(CHIBIOS)/os/ext/CMSIS/ST
RTOS kernel files.
reference:
$(CHIBIOS)/os/rt/rt.mk
source files:
$(CHIBIOS)/os/rt/src/chsys.c
$(CHIBIOS)/os/rt/src/chdebug.c
$(CHIBIOS)/os/rt/src/chvt.c
$(CHIBIOS)/os/rt/src/chschd.c
$(CHIBIOS)/os/rt/src/chthreads.c
$(CHIBIOS)/os/rt/src/chtm.c
$(CHIBIOS)/os/rt/src/chstats.c
$(CHIBIOS)/os/rt/src/chdynamic.c
$(CHIBIOS)/os/rt/src/chregistry.c
$(CHIBIOS)/os/rt/src/chsem.c
$(CHIBIOS)/os/rt/src/chmtx.c
$(CHIBIOS)/os/rt/src/chcond.c
$(CHIBIOS)/os/rt/src/chevents.c
$(CHIBIOS)/os/rt/src/chmsg.c
$(CHIBIOS)/os/rt/src/chmboxes.c
$(CHIBIOS)/os/rt/src/chqueues.c
$(CHIBIOS)/os/rt/src/chmemcore.c
$(CHIBIOS)/os/rt/src/chheap.c
$(CHIBIOS)/os/rt/src/chmempools.c
include folders:
$(CHIBIOS)/os/rt/include
RTOS kernel stm32 port files.
reference:
$(CHIBIOS)/os/rt/ports/ARMCMx/compilers/GCC/mk/port_v7m.mk
source files:
$(CHIBIOS)/os/rt/ports/ARMCMx/chcore.c
$(CHIBIOS)/os/rt/ports/ARMCMx/chcore_v7m.c
$(CHIBIOS)/os/rt/ports/ARMCMx/compilers/GCC/chcoreasm_v7m.s
include folders:
OSAL files.
reference:
$(CHIBIOS)/os/hal/osal/rt/osal.mk
source files:
${CHIBIOS}/os/hal/osal/rt/osal.c
include folders:
HAL files.
reference:
$(CHIBIOS)/os/hal/hal.mk
source files:
$(CHIBIOS)/os/hal/src/hal.c
$(CHIBIOS)/os/hal/src/hal_queues.c
$(CHIBIOS)/os/hal/src/hal_mmcsd.c
$(CHIBIOS)/os/hal/src/adc.c
$(CHIBIOS)/os/hal/src/can.c
$(CHIBIOS)/os/hal/src/dac.c
$(CHIBIOS)/os/hal/src/ext.c
$(CHIBIOS)/os/hal/src/gpt.c
$(CHIBIOS)/os/hal/src/i2c.c
$(CHIBIOS)/os/hal/src/i2s.c
$(CHIBIOS)/os/hal/src/icu.c
$(CHIBIOS)/os/hal/src/mac.c
$(CHIBIOS)/os/hal/src/mmc_spi.c
$(CHIBIOS)/os/hal/src/pal.c
$(CHIBIOS)/os/hal/src/pwm.c
$(CHIBIOS)/os/hal/src/rtc.c
$(CHIBIOS)/os/hal/src/sdc.c
$(CHIBIOS)/os/hal/src/serial.c
$(CHIBIOS)/os/hal/src/serial_usb.c
$(CHIBIOS)/os/hal/src/spi.c
$(CHIBIOS)/os/hal/src/st.c
$(CHIBIOS)/os/hal/src/uart.c
$(CHIBIOS)/os/hal/src/usb.c
include folders:
$(CHIBIOS)/os/hal/include
stm32 platform files.
reference:
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/platform.mk
source files:
$(CHIBIOS)/os/hal/ports/common/ARMCMx/nvic.c
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/stm32_dma.c
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/hal_lld.c
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/adc_lld.c
$(CHIBIOS)/os/hal/ports/STM32/STM32F1xx/ext_lld_isr.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/can_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/ext_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/mac_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/sdc_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/DACv1/dac_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/GPIOv1/pal_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/I2Cv1/i2c_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/RTCv1/rtc_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/SPIv1/spi_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/TIMv1/gpt_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/TIMv1/icu_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/TIMv1/pwm_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/TIMv1/st_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/USARTv1/serial_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/USARTv1/uart_lld.c
$(CHIBIOS)/os/hal/ports/STM32/LLD/USBv1/usb_lld.c
include folders:
board files.
source files:
$(your_board)/board.c
include folders:
$(your_board)
project build options
1.Device set "cortext-m3"
2.Link script set "$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/ld/stm32f103x8.ld"
3.Linker settings > Linker symbols add "__process_stack_size__=0x400" and "__main_stack_size__=0x400"
4.Assembler settings > Assembler Flags > Others set "-x assembler-with-cpp"
5.Search directories > includes add "above include folders"
6.Search directories > Linker add "$(CHIBIOS)/os/common/ports/ARMCMx/compilers/GCC/ld"
note: all of those could found in ChibiOS demo's Makefile and rules.mk files.
done!
Zhu
