the PWM callback doe not seem to work ??? PS i can see on scope the wavefrom....
ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
#include <stdio.h>
#include <string.h>
#include "ch.h"
#include "hal.h"
#include "shell.h"
#include "flash.h"
#include "candr.h"
#include "console.h"
#include "filesys.h"
#include "serialcom.h"
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS 1
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH 4
static void pwmpcb(PWMDriver *pwmp);
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
* ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
static PWMConfig pwmconf = {
10000,
10000,
pwmpcb,/* call back start ADC*/
{ /* Channel 3 on TIM2 enabled */
{PWM_OUTPUT_DISABLED, NULL},
{PWM_OUTPUT_ACTIVE_HIGH, NULL},
0,
0,
#if STM32_PWM_USE_ADVANCED
0
* ADC conversion group.
* Mode: Linear buffer, 4 samples of 2 channels, SW triggered.
* Channels: IN10 (41.5 cycles sample time)
* Sensor (239.5 cycles sample time)
FALSE,
ADC_GRP1_NUM_CHANNELS,
adccb,
NULL,
/* HW dependent part.*/
0,
ADC_CR2_TSVREFE,
ADC_SMPR1_SMP_AN14(ADC_SAMPLE_41P5),
0,
ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
0,
ADC_SQR1_SQ14_N(ADC_CHANNEL_IN14)
* PWM cyclic callback.
* A new ADC conversion is started.
(void)pwmp;
chSysLockFromISR();
adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
chSysUnlockFromISR();
* ADC end conversion callback.
* The PWM channels are reprogrammed using the latest ADC samples.
* The latest samples are transmitted into a single SPI transaction.
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
(void) buffer; (void) n;
/* Note, only in the ADC_COMPLETE state because the ADC driver fires an
intermediate callback when the buffer is half full.*/
if (adcp->state == ADC_COMPLETE)
adcsample_t avg_ch1;;
/* Calculates the average values from the ADC samples.*/
avg_ch1 = (samples[0] + samples[2] + samples[4] + samples[6]) / 4;
chSysLockFromISR();
/* Changes the channels pulse width, the change will be effective
starting from the next cycle.*/
pwmEnableChannelI(&PWMD2, 2, PWM_FRACTION_TO_WIDTH(&PWMD2, 4096, avg_ch1));
* LEDs blinker thread, times are in milliseconds.
static THD_FUNCTION(Thread1, arg)
(void)arg;
while (TRUE) {
palClearPad(GPIOF, GPIOF_LED4);
palSetPad(GPIOF, GPIOF_LED1);
chThdSleepMilliseconds(250);
palClearPad(GPIOF, GPIOF_LED1);
palSetPad(GPIOF, GPIOF_LED2);
palClearPad(GPIOF, GPIOF_LED2);
palSetPad(GPIOF, GPIOF_LED3);
palClearPad(GPIOF, GPIOF_LED3);
palSetPad(GPIOF, GPIOF_LED4);
* Application entry point.
int main(void) {
* System initializations.
* RTOS is active.
* Shell initialization.
shellInit();
* Candr initialization.
candrInit();
* Flash initialization.
flashInit();
* Console initialization.
consoleInit();
* filesys initialization.
filesysInit();
* Serial comms example initialization.
serialcomInit();
* Activates the serial driver 1 and SDC driver 1 using default
* configuration.
sdStart(&SD1, NULL);
sdcStart(&SDCD1, NULL);
* Initializes the ADC driver 1.
* The pin PC0 on the port GPIOC is programmed as analog input.
adcStart(&ADCD1, NULL);
adcStartConversion(&ADCD1,
&adcgrpcfg,
samples,
pwmStart(&PWMD2, &pwmconf);
// pwmEnableChannel(&PWMD2, 2, 200); // Port PB10
* Creates the blinker thread.
chThdCreateStatic(waThread1,
sizeof(waThread1),
NORMALPRIO,
Thread1, NULL);
AFIO->MAPR |= AFIO_MAPR_CAN_REMAP_REMAP2;
AFIO->MAPR |= AFIO_MAPR_TIM2_REMAP_FULLREMAP;
* sleeping in a loop and listen for events.
while (TRUE) {
chThdSleepMilliseconds(1000);
