chThdSleep strange behaviour
am3syl
Post by am3syl »
Hello guys,
First of all, thanks for this tremendous work. ChibiOS is great !
I have some trouble with a custom board using a STM32F427IIT6. It is probably a configuration problem because I have reduced the code to :
int main(void) {
chThdSleepMicroseconds(250);
while (TRUE) {
I use ChibiOS 16.1.
In debug mode the chThdSleepMicroseconds function never end ( debugger is lost at line 338 of chschd.c )
My chconf.h have all the values at the default values.
Nothing is activated in halconf.h
My mcuconf.h:
#define STM32F4xx_MCUCONF
 * HAL driver system settings.
#define STM32_HSI_ENABLED                   TRUE
#define STM32_LSI_ENABLED                   TRUE
#define STM32_CLOCK48_REQUIRED              TRUE
#define STM32_PLLM_VALUE                    24
#define STM32_PLLN_VALUE                    336
#define STM32_PLLP_VALUE                    2
#define STM32_PLLQ_VALUE                    7
#define STM32_PPRE1                         STM32_PPRE1_DIV4
#define STM32_PPRE2                         STM32_PPRE2_DIV2
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE                  8
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSI
#define STM32_MCO1PRE                       STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE                       STM32_MCO2PRE_DIV5
#define STM32_I2SSRC                        STM32_I2SSRC_CKIN
#define STM32_PLLI2SN_VALUE                 192
#define STM32_PLLI2SR_VALUE                 5
#define STM32_BKPRAM_ENABLE                 FALSE
Code works on other platforms ( stm32f7discovery with the demo config files )
Any idea of what happens?
Thanks
Re: chThdSleep strange behaviour
You need to stop the target and see where it hangs, enabling usual debug options in chconf.h is also a good idea.
Being a custom board it could be a problem with the oscillator. Try booting using HSI.
am3syl
Post by am3syl »
The program is in the infinite loop of the idle_thread, waiting for a timer interrupt which never came ( port_wait_for_interrupt ).
As you said it's probably the oscillator but I tried to change to HSI with:
#define STM32_HSE_ENABLED                   FALSE
#define STM32_SW                            STM32_SW_HSI
#define STM32_PLLSRC                        STM32_PLLSRC_HSI
#define STM32_PLLM_VALUE                    16
The problem remains, I will check the oscillator path entirely with MCO pin.
It is normal to break it in the idle loop, are you sure it does not exit chthdSleep()? try compiling using -O0 and place breakpoints, optimizations make those unreliable.
am3syl
Post by am3syl »
Yes I'm sure, the timer associate to system tick doesn't count even with HSI clock. I replace the stm32f427 by another but same thing happens.
I'm already in O0 optimisation.
It's look like a bad configuration or hardware malfunction. I will start over from scratch.
am3syl
Post by am3syl »
Errata the timer count but very slowly, probably prescaler settings
am3syl
Post by am3syl »
Forget the posts above, I'm sure of nothing :(
How I can ensure the chthdSleep is not exited? There is a interrupt to watch or something?
Look at the "st" (systick) driver, file name is /os/hap/ports/STM32/TIMv1/st_lld.c, timer ISRs are there, you could put a breakpoint there.
This is used for all the demos so it is unlikely a problem there. You most likely have a settings problem.
am3syl
Post by am3syl »
Some details:
Its seems I never go in the systick ISR.
TIM2 is higher than the CCR1 value, the compare/capture flag is set but no interrupt happens.
I will check the interrupt register and vectors things.
Are you using startups, vectors and ld files provided with ChibiOS?
