How to read and write on tx and rx
ChibiOS public support forum for topics related to the STMicroelectronics SPC56x family of automotive micro-controllers.
GianlucaLaManna
Post by GianlucaLaManna »
Hello.
I use SPC560P - DISP.
I enabled the serial communication LIN1. Then I set the pins TX and RX: TX output and RX input.
This is my code:
sdStart(&SD2, NULL);
chprintf((BaseSequentialStream *)&SD2, "V \r\n");
but it does not work.
Use SD1 because SD2 I use it with USB / Teraterm.
Re: How to read and write on tx and rx
Are I/O pins configured properly? also check clock settings.
SPC5Studio examples use serial ports, try starting from one of those.
GianlucaLaManna
Yes I know, but they don't use the rx and tx pad.
With the pin map wizard I set the pin 99 in RX and the pin 26 in TX.The function to write a character on the serial TX / RX is chprintf? It correct?
Correct.
GianlucaLaManna
Ok I try to control the setting of the pin and I'll know. Thanks
GianlucaLaManna
The software is ok. I think it's a problem of hardware setting.
I solved using SD1 and with 2 jumper using pins tx and rx near the programmer.
I'm using a bluetooth module and the tx and rx I take them in those two pins.
So use the same port. In fact I have the same output of Tera Term, and on the console of my smartphone.
So, for me, the thread is solved. I can communicate via Bluetooth. I have to see better setting some hardware jumpers.
Thank you.
