USB Serial does not transmit
Posted: Mon Feb 08, 2016 4:02 pm
MCU: stm32f072c8
RT v 16.1.3
I have implemented USB Serial. It successfully receives data from host using method SDU1.vmt->get.
But when I put sevral bytes with SDU1.vmt->put, host receives nothing. Driver does not tries send anything.
It seems that obnotify is to be called when transmit buffer is full.
Is this true? If yes - this is incorrect behavior. One should be able to send single byte to host
P.S. Just checked this out - sent 256 bytes, they were received by host successfully. A-a-a, panic, what should I do?
RT v 16.1.3
