Road to K64F port
Posted: Mon Feb 15, 2016 7:12 pm
Hey there,
I'm trying to port ChibiOS 3.0 on Freescale K64F in order to understand certain mechanisms and take a look deeper in this RTOS. Before to start, I'm configuring ChibiStudio (on Windows) and I have a problem related to the OpenOCD part.
Well, I know this is off-topic but the internet seems to be outdate on this topic,so I hope someone has faced (and solved) the same problem before. I'm using Open-SDA with CMSIS-DAP debug support. I have configured a new entry into external tools launching OpenOCD using as interface "cmsis-dap.cfg" but something goes wrong. It seems like the flash is in a secured state since I have received this reply:
Now, I have issued the command "kinetis mdm mass_erase" and OpenOCD works...
Until I disconnect/reconnect the USB: in this case the Flash comes back in a secured state...
Suggestions?
Regards,
RM
Open On-Chip Debugger 0.10.0-dev-00200-gdb56a3b (2016-02-10-18:08)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'swd'
Info : add flash_bank kinetis k60.flash
adapter speed: 1000 kHz
none separate
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 1.0
Info : SWCLK/TCK = 0 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 1000 kHz
Info : SWD IDCODE 0x2ba01477
Error: Failed to read memory at 0xe000ed00
Polling target k60.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Examination failed, GDB will be halted. Polling again in 6300ms
Error: Failed to read memory at 0xe000ef40
Error: Failed to read memory at 0xe000ef44
Error: Failed to read memory at 0xe0002000
Error: Failed to read memory at 0xe0001000
Info : k60.cpu: hardware has 0 breakpoints, 0 watchpoints
Warn : MDM: Secured MCU state detected however it may be a false alarm
Warn : MDM: Halting target to detect secured state reliably
Warn : target was in unknown state when halt was requested
Warn : MDM: Target not halted, trying reset halt
Warn : *********** ATTENTION! ATTENTION! ATTENTION! ATTENTION! **********
Warn : **** ****
Warn : **** Your Kinetis MCU is in secured state, which means that, ****
Warn : **** with exception for very basic communication, JTAG/SWD ****
Warn : **** interface will NOT work. In order to restore its ****
Warn : **** functionality please issue 'kinetis mdm mass_erase' ****
Warn : **** command, power cycle the MCU and restart OpenOCD. ****
Warn : **** ****
Warn : *********** ATTENTION! ATTENTION! ATTENTION! ATTENTION! **********Now, I have issued the command "kinetis mdm mass_erase" and OpenOCD works...
Info : k60.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : MDM: Chip is unsecured. Continuing.
k60.cpu: target state: halted
target halted due to debug-request, current mode: Thread Until I disconnect/reconnect the USB: in this case the Flash comes back in a secured state...
Suggestions?
Regards,
RM
