ADC conversion + Analog Watch Dog
Posted: Fri Mar 11, 2016 6:16 am
by Alex
moved from the my previous topic
Same problem, another way
this conversion group:
    static const ADCConversionGroup adc_cfg_wdg2 = {
      FALSE,
      2,
      NULL,
      adcerr_wdg,
      .u.adc = {
        ADC_CR1_AWDEN | ADC_CR1_AWDIE | ADC_CR1_AWDSGL | ADC_CR1_AWDCH_0 | ADC_CR1_AWDCH_3,
          ADC_CR2_SWSTART | ADC_CR2_CONT,
          NEGATIVE_VOLTAGE_LIMIT,
          POSITIVE_VOLTAGE_LIMIT,
        { 0,     ADC_SMPR2_SMP_AN8(ADC_SAMPLE_1P5) | ADC_SMPR2_SMP_AN9(ADC_SAMPLE_1P5)},
        { 0, 0,  ADC_SQR3_SQ2_N(ADC_CHANNEL_IN8)   | ADC_SQR3_SQ1_N(ADC_CHANNEL_IN9)}}};
and this call conversion
   adcStartConversionI(&ADCD1, &adc_cfg_wdg2, buf, ADC_WDG_BUFDEPTH);
if ADC_WDG_BUFDEPTH == 0, call adcerr_wdg, but not store results of conversion, (clear, ok)
if ADC_WDG_BUFDEPTH > 0, store results of conversion, but not call adcerr_wdg (why?) at the same conditions
I want both actions: store results of conversion, and call adcerr_wdg - this is possible?
clear up the point: I am interested in: store result of conversion at channel8 once of certain time period,
and check ranges of signal at channel9 during whole this period
PS: Device STM32F373C8T6, board- self made, OS - NIL from ChibiOs v3.0
PPS: Sorry for my Engish ...
thank you very much for you tolerance
Re: ADC conversion + Analog Watch Dog
Posted: Fri Mar 11, 2016 9:19 am
Buffer depth == 0 is forbidden, you should not do that.
About the WDG, when a WDG condition is detected the conversion is stopped and the driver goes into the ADC_ERROR state, you need to restart the conversion. It is strange that you don't get the callback, are you sure about this? I will make some tests over weekend.
Posted: Fri Mar 11, 2016 10:57 am
by Alex
Giovanni wrote:It is strange that you don't get the callback, are you sure about this?
I will repeat my approaches too.
some corrections:
if field <adc_callback> == NULL getting <adcerr_wdg> is regular,
but else getting <adcerr_wdg> is very rarely;
i use this call conversion now
adcStartConversionI(&ADCD1, &adc_cfg_wdg2, buf, 1);
          FALSE,
          2,
          NULL,
          adcerr_wdg,
          .u.adc = {
