Use-after-clear bug in adc_lld.c
Posted: Fri Apr 01, 2016 12:19 pm
Hi, I found a use-after-clear bug in adc_lld.c for the Kinetis branch.
Basically, in the adc ISR code, _adc_isr_full_code() is called and then ADCD1.grpp->circular is referenced.
However, adc_isr_full_code() will set ADCD1.grpp to NULL at the end of a conversion, causing the pointer dereference to yield bogus results. In my case, I was trying to do a single conversion but the bogus dereference would set the system into circular conversion mode, causing the subsequent conversion's ISR to enter with a NULL grpp structure, leading to all kinds of sadness.
Swapping the order of operations so the dereference happens prior to the isr callback seems to fix the problem for me.
