Page 1 of 3
STM32F030 and RTC
Posted: Fri May 06, 2016 1:53 am
by dflogeras
GCC-4.9.3, newlib-2.2.0, binutils-2.25, ChibiOS-3.0.5
I'm playing with a new chip, namely STM32F030. I'm interested in using its RTC to set an alarm and wake the device up after a snooze. I used the testhal/STM32F1xx/RTC program as a starting point and enabled the HAL_USE_RTC. When I try to compile, I get
main.c:133:3: warning: implicit declaration of function ‘rtcSTM32GetSecMsec’ [-Wimplicit-function-declaration]
   rtcSTM32GetSecMsec(&RTCD1, &tv_sec, NULL);
main.c:133:31: error: ‘tv_sec’ undeclared (first use in this function)
main.c:133:31: note: each undeclared identifier is reported only once for each function it appears in
main.c:134:12: error: ‘RTCAlarm’ has no member named ‘tv_sec’
   alarmspec.tv_sec = tv_sec + 20;
After looking in the specific rtc_lld.h, I see it is because STM32_HAS_PERIODIC_WAKEUPS is not defined in stm32_registry.h for this device. According to this the device's RTC does have periodic wakeup. I'm not sure how to fix this, help/advice is appreciated!
Re: STM32F030 and RTC
Posted: Fri May 06, 2016 10:37 am
by RoccoMarco
I will take a look. It could be a bug.
Thanks. Ciao,
RM
Posted: Fri May 06, 2016 1:16 pm
by dflogeras
Thanks Rocco! I'm happy to test patches if you do not have access to hardware.
Dave
Posted: Fri May 06, 2016 1:18 pm
by RoccoMarco
Thanks a lot... In this case I have a STM32 Nucleo64-F030R8. I am porting the RTC demo to test the HAL.
Posted: Fri May 06, 2016 1:34 pm
by RoccoMarco
So I am editing the DEMO. The biggest problems appears to be the missing of all the bit mask and structure related to Periodic Wakeup.
Posted: Fri May 06, 2016 2:19 pm
by dflogeras
I notice that in os/ext/CMSIS/ST/stm32f030x8.h there are a couple fields missing from the RTC_* related registers. For instance RTC_CR does not include RTC_CR_WUTE and RTC_CR_WUTIE, but the data sheet indicates these fields are present in the f030x6/8/C devices as well as the f070x6/B devices.
I assume that these headers come directly from ST/ARM and not ChibiOS, is there a newer CMSIS available that includes these? I'm not sure where they come from, I have an ARM CMSIS package downloaded to get the DSP libraries but it does not include these files.
Posted: Fri May 06, 2016 2:38 pm
by RoccoMarco
Indeed these headers comes directly from ST. Even more the RTC struct misses RTC_WUTR! It is very strange. I have checked documentation more than once looking for a note saying that wakeup is not available on STM32F030xx (without success).
Posted: Fri May 06, 2016 2:50 pm
Header files are those released by ST in Cube MX, our policy is to not modify them.
I suggest to post about this in the ST forums and ask if it is an header error or if the feature is really missing in the device.
Posted: Fri May 06, 2016 3:13 pm
by RoccoMarco
Giovanni wrote:Header files are those released by ST in Cube MX, our policy is to not modify them.
I can confirm. Indeed, We can not know whether the error is in the CMSIS header or documentation. I will ask on the STM32 forum. Until that moment we will assume that RTC doen't have periodic wakeup.
Ciao,
RM
Posted: Fri May 06, 2016 4:04 pm
by dflogeras
Thanks Rocco,
In the meantime I downloaded the latest headers from ST, and while there are numerous changes from the one included with ChibiOS-3.0.5 (ST ver 2.0.1, versue 2.2.3) they didn't add the registers/bitmaps in question.
Out of curiousity, if the HW itself doesn't support the periodic wakeups, does the current RTC driver implementations operate in a diminished mode, or not at all?
