SERIAL_USB and buffering.
rew
Been thanked: 14 times
Post by rew »
I have an application that used to work, except that now chibios has been updated stuff suddenly stopped working.... :-(
I have it almost working again, execept that my outputstream to SERIAL_USB is getting buffered where I don't want that. (if you type a character, I echo it back, it is not useful if that happens 3 minutes later).
How do I flush the SERIAL_USB output stream? Why do I have to do this explicitly now?
Re: SERIAL_USB and buffering.
Look at the demos, there is a function to associate to the periodic callback in order to flush the buffer.
viewtopic.php?t=3246
viewtopic.php?t=3166
rew
Post by rew »
Thank you.
Only 820 files with a total of 184 thousand Lines-Of-Code were changed between the version that worked and the current version. I searched for "flush" but didn't find anything... :-(
The trick is to not use the forum search, use Google with site:chibios.com, way better.
RoccoMarco
Has thanked: 83 times
Been thanked: 67 times
Post by RoccoMarco »
I'll improve forum search soon.
