Plans on merging the latest FatFS updates? Topic is solved
Korken
Has thanked: 5 times
Been thanked: 6 times
Post by Korken »
Hi Giovanni!
Are there plans for merging the latest FatFS updates?
There are some very nice features added since 0.10b, such as exFAT support (which I am after :) ) and bug fixes.
Best Regards
Emil
Re: Plans on merging the latest FatFS updates?
Hi Emil,
Sure but I am a bit busy of late. Maybe you could try it and provide feedback for integration.
Korken
Post by Korken »
I will have a look!
I am currently getting my first STM32F746 board up and running, so it might take a few days until I get to the SDIO part. :)
Side note:
The HW bug that makes you go into ISRs when single stepping (in the Cortex-M7) is super annoying.
Korken
Post by Korken »
Here are the updates for 0.12a. :)
Please have a look and see if something is amiss.
I have tested it on a custom STM32F746 board with 4-bit SDIO.
Sadly I do not have the boards that are used in the demos, so I just updated them with the new ffconf.h and fixed the main.c for the new features (corrected calculations and updated file-tree printing function).
What have been tested/done:
* Correct card size/free space
* Read
* Write
* FAT32
* exFAT
* Updated demos (ffconf.h / main.c), but only compilation test - no run test.
fatfs-0.12a-patched.7z
(1.34 MiB) Downloaded 436 times
0001-fatfs-0.12a-update.patch.zip
(10.63 KiB) Downloaded 474 times
Thanks, what are the main differences between the old and new versions? from the integration point of view.
Korken
Post by Korken »
The main changes are:
* Due to the exFAT support the calculation of memorycard size needed to be updated.
* The FILINFO structure has been updated on how it handles long filenames (hence the new file-tree printing function).
* Some flags have been removed/replaced (WORDACCES, USE_ERASE, ...).
* The number which selects locale had changed.
Korken
Post by Korken »
Hi, any updates on this? :)
After my vacations :)
Korken
Post by Korken »
Ah! Enjoy your vacations!
I just came back from mine, wished I had more. :)
Moving in "bug reports" before merging this.
