Page 1 of 3
ADCv2
Posted: Tue Aug 02, 2016 7:40 am
by neums
short question to ADCv2 (adc_lld_start_conversion):
Why writing ADC_CR2_CONT two times? And why not writing ADC_CR2_SWSTART?
  /* The start method is different dependign if HW or SW triggered, the
     start is performed using the method specified in the CR2 configuration.*/
  if ((cr2 & ADC_CR2_SWSTART) != 0) {
    /* Initializing CR2 while keeping ADC_CR2_SWSTART at zero.*/
    adcp->adc->CR2 = (cr2 | ADC_CR2_CONT) & ~ADC_CR2_SWSTART;
    /* Finally enabling ADC_CR2_SWSTART.*/
    adcp->adc->CR2 = (cr2 | ADC_CR2_CONT);
Re: ADCv2
Posted: Tue Aug 02, 2016 8:32 am
We need to enforce ADC_CR2_CONT even if not specified in the structure.
ADC_CR2_SWSTART is optionally written in the configuration structure but only in case of SW triggering, it must not be specified for HW triggering.
Comments could be better there.
Re: ADCv2
Posted: Tue Aug 02, 2016 9:54 am
by neums
but in the code the ADC_CR2_SWSTART flag is reset in CR2. And ADC_CR2_CONT is written twice.
Re: ADCv2
Posted: Tue Aug 02, 2016 10:00 am
ADC_CR2_CONT is not written twice, it is kept to 1 during the two writes like all bits specified in cr2. I want only ADC_CR2_SWSTART to toggle, if specified.
Re: ADCv2
Posted: Tue Aug 02, 2016 10:36 am
by neums
Sure...
2nd question: How to configure software triggered discontinuous mode when the ADC_CR2_CONT is forced? In the STM32F4 reference manual is described that a single sequence conversion is done with ADC_CR2_CONT=0.
Why it has to be enforced?
Re: ADCv2
Posted: Tue Aug 02, 2016 11:16 am
There is an assumption in the driver for the ADC to be in continuous mode. All channels in a conversion group are meant to be converted together.
The ADC driver implements a generic ADC behavior, it does not necessarily support all features of the underlying HW. The discontinuous mode is very STM32-specific.
Re: ADCv2
Posted: Tue Aug 02, 2016 4:37 pm
by neums
how to use the EOC and JEOC interrupt? I just see the DMA full transfer isr.
Re: ADCv2
Posted: Wed Aug 03, 2016 11:59 am
by neums
in the adc_lld_start_conversion the value L in sqr1 is not set. This value defines the length of the conversion group:
  /* ADC setup.*/
  adcp->adc->SR    = 0;
  adcp->adc->SMPR1 = grpp->smpr1;
  adcp->adc->SMPR2 = grpp->smpr2;
  adcp->adc->SQR1  = grpp->sqr1;
  adcp->adc->SQR2  = grpp->sqr2;
  adcp->adc->SQR3  = grpp->sqr3;
In the ADCv3 this value is set with the high level part value num_channels:
  adcp->adcm->SMPR1 = grpp->smpr[0];
  adcp->adcm->SMPR2 = grpp->smpr[1];
  adcp->adcm->SQR1  = grpp->sqr[0] | ADC_SQR1_NUM_CH(grpp->num_channels);
  adcp->adcm->SQR2  = grpp->sqr[1];
  adcp->adcm->SQR3  = grpp->sqr[2];
  adcp->adcm->SQR4  = grpp->sqr[3];
My channels are not converted if L is not set to num_channels. I tested it with the debugger. When I set L to num_channels then the ADC converts all channels defined in the sqr registers. Is this a bug or am i doing somthing wrong?
Re: ADCv2
Posted: Wed Aug 03, 2016 12:04 pm
I can't see any reason for the driver to NOT do that, it is a bug. Opening a ticket.
About EOC, there is no need for that, the DMA interrupt is sufficient, JEOC is not used because injected conversions are not supported by the driver model, a low level API could be implemented for that.
Re: ADCv2
Posted: Wed Aug 03, 2016 12:26 pm
by neums
thanks for opening a ticket.
To your 2nd answer. The interrupt is available for the error callback (ADC_SR_OVR leads to the same interrupt vector as ADC_SR_EOC and ADC_SR_JEOC). Could it be possible to have an event callback in the ADC driver for EOC and JEOC which is called in OSAL_IRQ_HANDLER(STM32_ADC_HANDLER) if it is unequal NULL? The event callback whould be local user code whos responsible to dispatch the ISR reason exactly. That might be plattform independent and a STM user has the opportunity the implement an EOC or JEOC callback. Sure, JEOC is only avaible if the injected channels whould be introduced in the low level part of this certain ADC driver. But this is also plattform independent.
Usecase:
I want to convert 10 channels continuously and SW triggered by interrupt. But i need also a timer triggered channel with higher priority.
