USB on STM32F4
Posted: Sun Mar 18, 2012 1:56 pm
by kpa
I have seen that STM32F1 have a USB support in ChibiOS but not STM32F4.
Do you already have plan to add the USB support for F4 ? If yes do you already know when it will be done ?
Is it complicated to add this support myself ? If not could you point me where I have to add ?
Thanks in advance for your help
kpa
Re: USB on STM32F4
Posted: Sun Mar 18, 2012 3:01 pm
It is already being implemented, some work has already been committed on the repository, the "when" is TBD, it is a very complex peripheral.
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 3:59 pm
by efs113
Which subversion tree has the commits? I'd like to take a look at what has been done so far.
Eric
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 4:08 pm
Hi Eric,
It is in the trunk, so far there is an header with all register definitions, it is very large, this peripheral has a lot of registers.
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 4:19 pm
by efs113
I've been working with the 'full speed' registers for a while now using the example in the Discovery code as a starting point. I've had some success; the chip enumerates and starts talking on the bus, but I get strange results when I try to read the setup packet. Was hoping to get some hints from your code.
Eric
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 4:27 pm
Hi Eric,
I already worked on that peripheral on another ST product but that code is proprietary and I can't show it, I don't remember problems with setup packets however.
The peripheral was a bit different because it was configured with a single TX FIFO but this should not impact the problem you mentioned.
I will be able to comment on this after rewriting that code and actually testing it.
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 5:10 pm
I found a possibly related discussion
here.
Interesting.
Re: USB on STM32F4
Posted: Mon Mar 19, 2012 6:02 pm
by efs113
Your search fu is better than mine ...
I'm seeing similar behavior. When I read the GRXSTSP register I see 0x01000680 which is an invalid status. It may be a timing issue. I'll take a look at their code and see if it gives me any hints.
Eric
