STM32F105 and EXT
Posted: Wed Sep 28, 2016 11:35 am
by Beredrim
Hello again.
I believe I may have found another problem with the STM32F105 HAL. This time concerning the EXT module.
I encountered it in ChibiOs stable 16.1.5. I have not actuallly compiled with latest trunk to test it there (as it requires several other modifications for me to go from 16.1.5 to trunk. Want to stay on stable versions as far as possible). However from looking at the sources I believe it to be a problem in the trunk as well. If required I can test this as well, but I fear I do not have the time at my hands at the moment. If you need me to test it against the trunk please let me know, and I will do so as soon as I can and get back to you.
[r9813] :trunk/os/hal/ports/STM32/STM32F1xx/hal_ext_lld_isr.c -- ext_lld_exti_irq_enable() -- starting at line 322:
#if defined(STM32F10X_CL)
  /* EXTI vectors specific to STM32F1xx Connectivity Line.*/
  nvicEnableVector(OTG_FS_WKUP_IRQn, STM32_EXT_EXTI18_IRQ_PRIORITY);
  nvicEnableVector(ETH_WKUP_IRQn, STM32_EXT_EXTI19_IRQ_PRIORITY);
#elif  defined(STM32F10X_MD_VL) || defined(STM32F10X_HD_VL)
F105 belongs to the connectivity line (together with F107) but does not have ethernet.
Thus the ETH_WKUP_IRQn is not specified in the CMSIS file from ST for the F105.
([r9813]: trunk/os/common/ext/CMSIS/ST/STM32F1xx/stm32f105xc.h)
I believe adding e.g. #if defined(STM32F107xC) or #if !defined(STM32F105xC) would do the trick, but perhaps that would be the wrong way to address the issue.
Note: The ETH_WKUP_IRQn is also referenced at line 353 in hal_ext_lld_isr.c, so a fix might be needed there as well.
Best regards,
Daniel
Re: STM32F105 and EXT
Posted: Wed Sep 28, 2016 11:42 am
by RoccoMarco
Hi Daniel,
I will take a look in the next days. I am quite busy with EX right now. I will keep you up to date. Thanks for reporting.
Posted: Mon Oct 03, 2016 2:07 pm
by RoccoMarco
Fixed as Bug 782
Posted: Mon Oct 03, 2016 2:22 pm
by Beredrim
Thanks!
Posted: Mon Oct 03, 2016 2:24 pm
by RoccoMarco
Thank you for accurate reporting.
