stm32f37x sdadc timer trigger support
Posted: Tue Nov 01, 2016 9:05 pm
by noah
Hi all
The SDADC on the stm32f37x supports timer triggering, e.g. trigger SDADC3 from TIM12_CH2. There is no implementation in HAL 16 for enabling timer triggering, has someone done that before? The only option i see now would be to disable ADC HAL and do everything by hand...
Thanks for the reply
Cheers
Re: stm32f37x sdadc timer trigger support
Posted: Tue Nov 01, 2016 10:20 pm
Can't it be enabled by setting properly CR2 in the group configuration structure? is there something missing?
Posted: Wed Nov 02, 2016 2:58 pm
by noah
but there is no routine for initializing a timer channel for output compare when using the timer as GPT, is there?
Posted: Wed Nov 02, 2016 3:13 pm
GPT is only able to generate TRGO events, SDADC cannot use TRGO for some reason, you could use the PWM driver which uses output compare events for the de-activation front.
Posted: Thu Nov 03, 2016 10:26 pm
by noah
Finally figuered it out:
#define SDADC_CR2_JEXTSEL_M(n) ((n)<<8)
#define SDADC_CR2_JEXTEN_M(n) ((n)<<13)
static const ADCConversionGroup adcgrpcfg1 = {
TRUE, // circular
ADC_GRP1_NUM_CHANNELS, // num_channels
adccallback, // end_cb
adcerrorcallback, // error_cb
.u.sdadc = {
/* CR2: select rising edge of TIM12_CH2*/
SDADC_CR2_JEXTSEL_M(0x02) | SDADC_CR2_JEXTEN_M(0x01), // thats the important stuff
SDADC_JCHGR_CH(ADC_GRP1_CHANNEL),
SDADC_CONFCHR1_CH6(0), //
SDADC_CONFCHR1_CH6(0), // use configuration 0 for channel 6
then simply just start the correct timer as PWM output (PWMD2 CH4 in my case) and launch a continous conversion using adcStartConversion and you're good.
Thanks for the hint @Giovanni!
