Problem with uart_lld.c
Giapptvn1412
Post by Giapptvn1412 »
Am I not configuring something correctly here? when i wirte #include "hal.h" in the file uart_lld.c. Keil C error I2c2 not present in the selected device.
Who can answer me? Thank you very much
Re: Problem with uart_lld.c
Just read this part "I2c2 not present in the selected device".
Disable I2C2 in mcuconf.h.
Giapptvn1412
Can i init I2c2 if disable i2c2 in mcuconfig.h. my understanding, is enabled I2C2 when #define STM32_HAS_I2C2 TRUE and #define STM32_I2C_USE_I2C2 TRUE
Apparently your device does not have I2C2 so you cannot initialize it.
Giapptvn1412
Thank you for the answer. . My Device STM32F103s8t6. I want to initialize the I2С2. How to enable the I2C2 to use slave? I'm sory, I'm new to chibios.
The STM32F103T6 does not have I2C2.
http://www.st.com/content/st_com/en/pro ... 103t6.html
Giapptvn1412
Hi. I think there's something.
STM32F103C8T6 has I2C2.
http://www.st.com/content/st_com/en/pro ... 103c8.html
Do you have a custom board.h?
Make sure to define STM32F103xB in board.h, x8 devices are not directly supported, xB are the closest ones.
Giapptvn1412
#ifndef _BOARD_H_
#define _BOARD_H_
 * Setup for  STM32F1 board.
 * Board identifier.
#define BOARD_KOSAGI_STM32F1_SENOKO
#define BOARD_NAME                  " STM32F103C8T6"
 * Board oscillators-related settings.
 * NOTE: HSE not fitted.
#if !defined(STM32_LSECLK)
#define STM32_LSECLK                32768
#if !defined(STM32_HSECLK)
#define STM32_HSECLK                0
 * Board voltages.
 * Required for performance limits calculation.
#define STM32_VDD                   330
 * MCU type as defined in the ST header file stm32f1xx.h.
#define STM32F10X_MD
 * IO pins assignments.
#define PA0   0
#define PA1   1
#define PA2   2
#define PA3   3
#define PA4   4
#define PA5   5
#define PA6   6
#define PA7   7
#define PA8   8
#define PA9   9
#define PA10  10
#define PA11  11
#define PA12  12
#define PA13  13
#define PA14  14
#define PA15  15
#define PB0   0
#define PB1   1
#define PB2   2
#define PB3   3
#define PB4   4
#define PB5   5
#define PB6   6
#define PB7   7
#define PB8   8
#define PB9   9
#define PB10  10
#define PB11  11
#define PB12  12
#define PB13  13
#define PB14  14
#define PB15  15
#define PC0   0
#define PC1   1
#define PC2   2
#define PC3   3
#define PC4   4
#define PC5   5
#define PC6   6
#define PC7   7
#define PC8   8
#define PC9   9
#define PC10  10
#define PC11  11
#define PC12  12
#define PC13  13
#define PC14  14
#define PC15  15
#define PD0   0
#define PD1   1
#define PD2   2
#define PD3   3
#define PD4   4
#define PD5   5
#define PD6   6
#define PD7   7
#define PD8   8
#define PD9   9
#define PD10  10
#define PD11  11
#define PD12  12
#define PD13  13
#define PD14  14
#define PD15  15
#define PE0   0
#define PE1   1
#define PE2   2
#define PE3   3
#define PE4   4
#define PE5   5
#define PE6   6
#define PE7   7
#define PE8   8
#define PE9   9
#define PE10  10
#define PE11  11
#define PE12  12
#define PE13  13
#define PE14  14
#define PE15  15
 * I/O ports initial setup, this configuration is established soon after reset
 * in the initialization code.
 * Please refer to the STM32 Reference Manual for details.
#define PIN_OSPEED_INPUT(n)         (0U << (((n) & 7) * 4))
#define PIN_OSPEED_10M(n)           (1U << (((n) & 7) * 4))
#define PIN_OSPEED_2M(n)            (2U << (((n) & 7) * 4))
#define PIN_OSPEED_50M(n)           (3U << (((n) & 7) * 4))
/* Input (cnf) */
#define PIN_MODE_ANALOG(n)          (0U << ((((n) & 7) * 4) + 2))
#define PIN_MODE_FLOATING(n)        (1U << ((((n) & 7) * 4) + 2))
#define PIN_MODE_INPUT(n)           (2U << ((((n) & 7) * 4) + 2))
/* Output (cnf) */
#define PIN_OTYPE_PUSHPULL(n)       (0U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_OPENDRAIN(n)      (1U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_AF_PUSHPULL(n)    (2U << ((((n) & 7) * 4) + 2))
#define PIN_OTYPE_AF_OPENDRAIN(n)   (3U << ((((n) & 7) * 4) + 2))
/* Set not-present pins to floating inputs */
#define PIN_NOTPRESENT(n)           (4U << (((n) & 7) * 4))
#define PIN_UNUSED(n)               PIN_NOTPRESENT(n)
/* Output data (ODR) */
#define PIN_ODR_HIGH(n)             (1U << ((n) & 7))
#define PIN_ODR_LOW(n)
#define VAL_GPIOA_CRL   ( 0 \
        /* CHG_CRIT */ \
        | PIN_OSPEED_INPUT(PA0) \
        | PIN_MODE_FLOATING(PA0) \
        | PIN_UNUSED(PA1) \
        | PIN_UNUSED(PA2) \
        | PIN_UNUSED(PA3) \
        /* ANA_METER */ \
        | PIN_OSPEED_INPUT(PA4) \
        | PIN_MODE_ANALOG(PA4) \
        /* ADC_IN5 */ \
        | PIN_OSPEED_INPUT(PA5) \
        | PIN_MODE_ANALOG(PA5) \
        /* ADC_IN6 */ \
        | PIN_OSPEED_INPUT(PA6) \
        | PIN_MODE_ANALOG(PA6) \
        /* ADC_IN7 */ \
        | PIN_OSPEED_INPUT(PA7) \
        | PIN_MODE_ANALOG(PA7) \
        | 0)
#define VAL_GPIOA_CRH   ( 0 \
        /* CHG_ACOK */ \
        | PIN_OSPEED_INPUT(PA8) \
        | PIN_MODE_FLOATING(PA8) \
        /* USART1_TX */ \
        | PIN_OSPEED_2M(PA9) \
        | PIN_OTYPE_AF_PUSHPULL(PA9) \
        /* USART1_RX */ \
        | PIN_OSPEED_INPUT(PA10) \
        | PIN_MODE_FLOATING(PA10) \
        /* GG_SYSPRES */ \
        | PIN_OSPEED_2M(PA11) \
        | PIN_OTYPE_PUSHPULL(PA11) \
        /* CHG_CE */ \
        | PIN_OSPEED_2M(PA12) \
        | PIN_OTYPE_PUSHPULL(PA12) \
        /* CHG_PWRSWITCH2 (formerly JTMS-SWDIO) */ \
        | PIN_OSPEED_INPUT(PA13) \
        | PIN_MODE_FLOATING(PA13) \
        /* JTCK / SWCLK */ \
        | PIN_OSPEED_INPUT(PA14) \
        | PIN_MODE_FLOATING(PA14) \
        /* JTDI */ \
        | PIN_OSPEED_INPUT(PA15) \
        | PIN_MODE_FLOATING(PA15) \
        | 0)
 * Pull GG_SYSPRES low to enable gas gauge,
 * and CHG_CE high to enable charging
#define VAL_GPIOA_ODR (( 0U << 11 ) | ( 1U << 12 ))
#define VAL_GPIOB_CRL   ( 0 \
        /* CHG_ICOUT */ \
        | PIN_OSPEED_INPUT(PB0) \
        | PIN_MODE_FLOATING(PB0) \
        /* NC */ \
        | PIN_UNUSED(PB1) \
        /* Programming mode */ \
        | PIN_UNUSED(PB2) \
        /* PM_JTDO */ \
        | PIN_OSPEED_2M(PB3) \
        | PIN_OTYPE_OPENDRAIN(PB3) \
        /* PM_JRST */ \
        | PIN_OSPEED_INPUT(PB4) \
        | PIN_MODE_FLOATING(PB4) \
        /* NC */ \
        | PIN_UNUSED(PB5) \
        | PIN_UNUSED(PB6) \
        | PIN_UNUSED(PB7) \
        | 0)
#define VAL_GPIOB_CRH   ( 0 \
        /* PM_REFLASH_ALRT */ \
        | PIN_UNUSED(PB8) \
        /* NC */ \
        | PIN_UNUSED(PB9) \
        /* CHG_SCL */ \
        | PIN_OSPEED_2M(PB10) \
        | PIN_OTYPE_AF_OPENDRAIN(PB10) \
        /* CHG_SDA */ \
        | PIN_OSPEED_2M(PB11) \
        | PIN_OTYPE_AF_OPENDRAIN(PB11) \
        /* CHG_ALERT */ \
        | PIN_OSPEED_INPUT(PB12) \
        | PIN_MODE_INPUT(PB12) \
        /* NC */ \
        | PIN_UNUSED(PB13) \
        /* CHG_PWRSWITCH */ \
        | PIN_OSPEED_INPUT(PB14) \
        | PIN_MODE_FLOATING(PB14) \
        /* CHG_MASTERPWR */ \
        | PIN_OSPEED_2M(PB15) \
        | PIN_OTYPE_PUSHPULL(PB15) \
        | 0 )
/* master power (PB15) on */
/* Pull alert (PB15) high */
/* Pull CHG_PWRSWITCH_EXT (PB3) high */
#define VAL_GPIOB_ODR ((1U << 15) | (1U << 12) | (1U << 3))
#define VAL_GPIOC_CRL   ( 0 \
        | PIN_NOTPRESENT(PC0) \
        | PIN_NOTPRESENT(PC1) \
        | PIN_NOTPRESENT(PC2) \
        | PIN_NOTPRESENT(PC3) \
        | PIN_NOTPRESENT(PC4) \
        | PIN_NOTPRESENT(PC5) \
        | PIN_NOTPRESENT(PC6) \
        | PIN_NOTPRESENT(PC7) \
#define VAL_GPIOC_CRH   ( 0 \
        | PIN_NOTPRESENT(PC8) \
        | PIN_NOTPRESENT(PC9) \
        | PIN_NOTPRESENT(PC10) \
        | PIN_NOTPRESENT(PC11) \
        | PIN_NOTPRESENT(PC12) \
        /* TAMPER-RTC */ \
        | PIN_UNUSED(PC13) \
        /* PM_OSC32_IN */ \
        | PIN_OSPEED_INPUT(PC14) \
        | PIN_MODE_INPUT(PC14) \
        /* PM_OSC32_OUT */ \
        | PIN_OSPEED_INPUT(PC15) \
        | PIN_MODE_INPUT(PC15) \
        | 0)
#define VAL_GPIOC_ODR 0
#define VAL_GPIOD_CRL   ( 0 \
        | PIN_UNUSED(PD0) \
        | PIN_UNUSED(PD1) \
        | PIN_NOTPRESENT(PD2) \
        | PIN_NOTPRESENT(PD3) \
        | PIN_NOTPRESENT(PD4) \
        | PIN_NOTPRESENT(PD5) \
        | PIN_NOTPRESENT(PD6) \
        | PIN_NOTPRESENT(PD7) \
        | 0)
#define VAL_GPIOD_CRH   ( 0 \
        | PIN_NOTPRESENT(PD8) \
        | PIN_NOTPRESENT(PD9) \
        | PIN_NOTPRESENT(PD10) \
        | PIN_NOTPRESENT(PD11) \
        | PIN_NOTPRESENT(PD12) \
        | PIN_NOTPRESENT(PD13) \
        | PIN_NOTPRESENT(PD14) \
        | PIN_NOTPRESENT(PD15) \
        | 0)
#define VAL_GPIOD_ODR 0
#define VAL_GPIOE_CRL   ( 0 \
        | PIN_NOTPRESENT(PE0) \
        | PIN_NOTPRESENT(PE1) \
        | PIN_NOTPRESENT(PE2) \
        | PIN_NOTPRESENT(PE3) \
        | PIN_NOTPRESENT(PE4) \
        | PIN_NOTPRESENT(PE5) \
        | PIN_NOTPRESENT(PE6) \
        | PIN_NOTPRESENT(PE7) \
        | 0)
#define VAL_GPIOE_CRH   ( 0 \
        | PIN_NOTPRESENT(PE8) \
        | PIN_NOTPRESENT(PE9) \
        | PIN_NOTPRESENT(PE10) \
        | PIN_NOTPRESENT(PE11) \
        | PIN_NOTPRESENT(PE12) \
        | PIN_NOTPRESENT(PE13) \
        | PIN_NOTPRESENT(PE14) \
        | PIN_NOTPRESENT(PE15) \
        | 0)
#define VAL_GPIOE_ODR 0
#if !defined(_FROM_ASM_)
#ifdef __cplusplus
extern "C" {
  void boardInit(void);
#ifdef __cplusplus
#endif /* _FROM_ASM_ */
#endif /* _BOARD_H_ */
//// My board.h
What ChibiOS version are you using? that board file is very old.
