Stuck in idle_thread after wake from STOP
chrismerck
Been thanked: 4 times
Post by chrismerck »
I'm trying to get wake from SLEEP/STOP mode working on STM32L151CC, with ChibiOS 16.1.0.
We first initialize the project, including starting debug serial port and setting EXTI 20 (for RTC wakeup event):
void extcb(EXTDriver *extp, expchannel_t channel)
   (void) extp;
   (void) channel;
   /* Reset SLEEPDEEP bit of Cortex System Control Register */
   SCB->SCR &= (uint32_t) ~((uint32_t) SCB_SCR_SLEEPDEEP_Msk);
   /* switch off wakeup */
   rtcSTM32SetPeriodicWakeup(&RTCD1, NULL);
   chSysLockFromISR();
   /* we must reinit clocks after waking up ESPECIALLY if use HSE or HSI+PLL */
   stm32_clock_init();
   chSysUnlockFromISR();
    {EXT_CH_MODE_DISABLED, NULL},
    {EXT_CH_MODE_DISABLED, NULL}, //{EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOB, extcb_enc}, // example interrupt
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART, extcb}, /* 20 */
int main(void) {
   * Real-Time Operating System Initialization
   *   RTOS is active.
   * Activates the EXT driver 1.
  extStart(&EXTD1, &extcfg);
Next we initialize the RTC:
void RTC_Init()
  int i = 0;
  // enable backup and pwr clocks
  RCC->APB1ENR |= RCC_APB1ENR_PWREN;
  PWR->CR |= PWR_CR_DBP;
  // reset RTC
  RCC->CSR |= RCC_CSR_RTCRST;
  RCC->CSR &= ~RCC_CSR_RTCRST;
  // enable LSE and wait for it to stabilize
  RCC->CSR |= RCC_CSR_LSION;
  while (!(RCC->CSR & RCC_CSR_LSIRDY))
    OsSleepMs(100);
    i++;
    if (i>50)
      SysError("LSI did not stabilize.");
      break;
    if (i%5) SysInfo("Waiting for LSI to stabilize...");
  SysInfo("LSI stable.");
  // reset RTC
  // enable RTC with external 32kHz xtal
  RCC->CSR |= RCC_CSR_RTCSEL_LSI;
  RCC->CSR |= RCC_CSR_RTCEN;
  //RTC->CR &= (uint16_t)~0x0008;
  //while (!(RTC->CR & 0x8));
  //while (!(RTC->CR & 0x20));
  //RTC->CR |= RTC_CR_ALRAIE;
And then set a 3 sec timer with RTC_DeepSleep(3):
void RTC_DeepSleep(uint32_t seconds)
   * use ck_spre (1Hz internal clock)
   * WUCKSEL[2:1] = 10 (1s to 18h)
   * Clear WUTE in RTC_CR to disable wkup timer
   * Poll WUTWF until it is set in RTC_ISR to make sure the access
   *   to the wakeup auto-reload counter and to WUCKSEL[2:0] bits is allowed.
   *   This takes ~2RTCCLK cycles.
   * Program the wakeup auto-reload value WUT[15:0],
   *   and the wakeup clock selection (WUCKSEL[2:0] in RTC_CR).
   *   Set WUTE in RTC_CR to enable timer again.
  // sleep up to 18h
  OsAssert(seconds < 65536,"RTC Assert");
  // unlock RTC regs
  RTC->WPR = 0xCA;
  RTC->WPR = 0x53;
  RTC->PRER |= RTC_PRER_PREDIV_A; // maximum async prediv
  RTC->PRER = (RTC->PRER & RTC_PRER_PREDIV_S) | 0x122; // 1Hz from 37kHz
  RTC->CR &= ~RTC_CR_WUTE;
  while (!(RTC->ISR & RTC_ISR_WUTWF)) {};
  RTC->WUTR = (RTC->WUTR & ~RTC_WUTR_WUT) | (seconds & RTC_WUTR_WUT);
  RTC->CR = (RTC->CR & ~RTC_CR_WUCKSEL) | (RTC_CR_WUCKSEL_2 /* 10x */);
  RTC->CR |= RTC_CR_WUTE;
  RTC->CR |= RTC_CR_WUTIE;
  // clear wakeup timer flag
  RTC->ISR &= ~(RTC_ISR_ALRBF | RTC_ISR_ALRAF | RTC_ISR_WUTF | RTC_ISR_TAMP1F |
                      RTC_ISR_TSOVF | RTC_ISR_TSF);
  // lock RTC regs
  RTC->WPR = 0xFF;
And finally call WFI:
    /* ADC1->CR2 = 0; // ADC off
    USART1->CR1 = 0;
    USART2->CR1 = 0;
    USART3->CR1 = 0;*/
    PWR->CR |= PWR_CR_ULP;
    PWR->CR |= PWR_CR_LPSDSR;
    //PWR->CR |= PWR_CR_PDDS; // standby
    for(int i = 0; i < 100; i++) {
      __NOP();
      __NOP();
      __NOP();
      __NOP();
      __NOP();
    SCB->SCR |= SCB_SCR_SLEEPDEEP;
      __NOP();
      __NOP();
      __NOP();
      __NOP();
      __NOP();
    __WFI();
Then three seconds later, the system wakes, we are able to print to the debug serial port, but then a call to OsSleepMs (chThdSleepMilliseconds) never returns. Debugger shows system enters but never leaves idle thread.
What might need to be re-initialized in ChibiOS to allow normal operation after waking from STOP?
Koen
Been thanked: 5 times
Re: Stuck in idle_thread after wake from STOP
Post by Koen »
Hello, it might be easier with Idle thread hooks (chconf.h) :
#define CORTEX_ENABLE_WFI_IDLE              TRUE
 * @brief   Idle thread enter hook.
 * @note    This hook is invoked within a critical zone, no OS functions
 *          should be invoked from here.
 * @note    This macro can be used to activate a power saving mode.
#ifndef  _FROM_ASM_
#define CH_CFG_IDLE_ENTER_HOOK() {                                          \
  extern bool stop_mode;                                                  \
  if(stop_mode) {                                                         \
       uint32_t   tmpreg  = PWR->CR1;                                     \
                  tmpreg &= (uint32_t) ~(PWR_CR1_PDDS | PWR_CR1_LPDS);    \
                  tmpreg |= PWR_CR1_LPDS;                                 \
    PWR->CR1  = tmpreg;                                                 \
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;                                  \
 * @brief   Idle thread leave hook.
 * @note    This macro can be used to deactivate a power saving mode.
#ifndef  _FROM_ASM_
  #define CH_CFG_IDLE_LEAVE_HOOK() {                                      \
    SCB->SCR &= (uint32_t)~((uint32_t)SCB_SCR_SLEEPDEEP_Msk);           \
This example does not contain clocks reinitialization. Declare bool stop_mode somewhere and assign it true/false depending on your wish to enter STOP or SLEEP mode.
chrismerck
Hi Koen,
Thanks for the reply. Indeed the idlethread hooks are a nice feature, however I will likely not be able to use them because I plan to take extreme steps to lower power consumption during STOP mode, including setting all GPIOs to analog inputs. But I would not want GPIOs modified every time the idle thread runs.
Does that make sense, or am I missing your point?
-Chris
Leaving the idle thread is done by serving interrupts that cause other threads to become ready, are interrupts enabled at that point? especially the systick timer.
Koen
Post by Koen »
The example above (with more logic of course) works great to always be in the lowest consumption configuration possible.
