STM32 USB OTG SV#6, misplaced @p chSysLockFromISR()..
Posted: Mon Jan 09, 2017 8:34 am
I use latest trunk with STM32F767 on custom board with HS USB phy.
I have added device qualifier descriptor to my usbcfg.c to be able to
pass USB2CV tests.
And have panic from usbDisableEndpointsI function:
When I commented out lock/unlock calls on lines #420 and #427 in hal_usb.c than code
works as expected and passed USB2CV tests.
It looks like trivial bug but I am not sure because USB code in HAL is too complex for me.
pass USB2CV tests.
* @define Device Descriptor size.
#define USB_DEVICE_QUALIFIER_SIZE 10U
* @brief Device Descriptor helper macro.
#define USB_DEVICE_QUALIFIER(bcdUSB, bDeviceClass, bDeviceSubClass, \
bDeviceProtocol, bMaxPacketSize, \
bNumConfigurations, bReserved) \
USB_DESC_BYTE(USB_DEVICE_QUALIFIER_SIZE), \
USB_DESC_BYTE(USB_DESCRIPTOR_DEVICE_QUALIFIER), \
USB_DESC_BCD(bcdUSB), \
USB_DESC_BYTE(bDeviceClass), \
USB_DESC_BYTE(bDeviceSubClass), \
USB_DESC_BYTE(bDeviceProtocol), \
USB_DESC_BYTE(bMaxPacketSize), \
USB_DESC_BYTE(bNumConfigurations), \
USB_DESC_BYTE(bReserved)
* USB Device Descriptor.
static const uint8_t vcom_device_qualifier_data[USB_DEVICE_QUALIFIER_SIZE] = {
USB_DEVICE_QUALIFIER (0x0200, /* bcdUSB (2.0). */
0x00, /* bDeviceClass (http://www.usb.org/developers/defined_class). */
0x00, /* bDeviceSubClass. */
0x00, /* bDeviceProtocol. */
0x40, /* bMaxPacketSize. */
0, /* bNumConfigurations. */
0) /* bReserved. */
* Device Descriptor wrapper.
static const USBDescriptor vcom_device_qualifier_descriptor = {
sizeof vcom_device_qualifier_data,
};And have panic from usbDisableEndpointsI function:
Thread [1] (Suspended: Signal 'SIGTRAP' received. Description: Trace/breakpoint trap.)
12 uav_panic_handler() fault_handlers.c:148 0x00214cbc
11 chSysHalt() chsys.c:203 0x002008a4
10 _dbg_check_lock_from_isr() chdebug.c:179 0x00200a48
9 chSysLockFromISR() chsys.h:418 0x002065ee
8 osalSysLockFromISR() osal.h:515 0x00206646
7 usbDisableEndpointsI() hal_usb.c:420 0x00206dba
6 default_handler() hal_usb.c:152 0x002068c4
5 _usb_ep0setup() hal_usb.c:769 0x002071ea
4 otg_epout_handler() hal_usb_lld.c:416 0x00209b7a
3 usb_lld_serve_interrupt() hal_usb_lld.c:621 0x0020a0bc
2 Vector174() hal_usb_lld.c:667 0x0020a130
1 <symbol is not available> 0xffffffec When I commented out lock/unlock calls on lines #420 and #427 in hal_usb.c than code
