STM32F4 & IAR
Posted: Tue Jan 31, 2017 5:43 pm
by yosoufe
Hi
I am trying to run the chibios on stm32f4-Discovery board with IAR! In the version that I have downloaded from the sourceforge there is no demo example for IAR and STM32F4. I have tried to use the STM32F3 demo. The blinking demo is working but I've got this warning during the debug session. This warning does not appear during the compilation:
Tue Jan 31, 2017 17:40:50: The stack pointer for stack 'CSTACK' (currently 0x20000400) is outside the stack range (0x2001F000 to 0x20020000)
How much dangerous is it? I am wondering if the code becomes bigger, would it cause problems? Can you introduce me some easy tutorials about writing the icf file and specially icf for the chibiOS.
Yousof
Re: STM32F4 & IAR
Posted: Tue Jan 31, 2017 7:15 pm
That warning is normal, that debugger assumes one execution thread and one stack, using an RTOS there are multiple stacks and the debugger thinks it overflowed, nothing to worry about. Not sure about why it assumes the stack to be in that range.
About the ICF, it is better if you take the one provided with the F3 demo and just adjust memory areas for the F4.
Re: STM32F4 & IAR
Posted: Wed Feb 01, 2017 10:35 am
by yosoufe
Thanks a lot
Sorry. I am not at all profi in this area. I may ask silly questions.
this is the memory map of the stm32f407 on the discovery board from its datasheet
and the following is the icf file that I may use
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x08000000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x08000000;
define symbol __ICFEDIT_region_ROM_end__ = 0x0801FFFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x20000000;
define symbol __ICFEDIT_region_RAM_end__ = 0x2001FFFF;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x2000;
define symbol __ICFEDIT_size_heap__ = 0x2000;
/**** End of ICF editor section. ###ICF###*/
/* Size of the IRQ Stack (Main Stack).*/
define symbol __ICFEDIT_size_irqstack__ = 0x400;
define memory mem with size = 4G;
define region ROM_region = mem:[from __ICFEDIT_region_ROM_start__ to __ICFEDIT_region_ROM_end__];
define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__ to __ICFEDIT_region_RAM_end__];
define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ {section CSTACK};
define block IRQSTACK with alignment = 8, size = __ICFEDIT_size_irqstack__ {};
define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ {};
define block SYSHEAP with alignment = 8 {section SYSHEAP};
define block DATABSS with alignment = 8 {readwrite, zeroinit};
initialize by copy { readwrite };
do not initialize { section .noinit };
keep { section .intvec };
place at address mem:__ICFEDIT_intvec_start__ {section .intvec};
place in ROM_region {readonly};
place at start of RAM_region {block IRQSTACK};
place in RAM_region {block DATABSS, block HEAP};
place in RAM_region {block SYSHEAP};
place at end of RAM_region {block CSTACK};
where should I fit the system memory in the table above in my icf file? is the file correct? I feel the system memory is missing in the icf file now! because I can guess the flash area is ROM and the SRAM areas are RAM in Chibios icf file. but nothing corresponds to system memory or CCRAM_region (called by icf default file from IAR)
Re: STM32F4 & IAR
Posted: Wed Feb 01, 2017 11:17 am
Sorry, I don't understand the problem.
Just take the Flash and RAM ranges you want to use and put them in the "Memory Regions" section of the ICF file.
Re: STM32F4 & IAR
Posted: Wed Feb 01, 2017 11:36 am
by yosoufe
Giovanni wrote:Hi,
In the ICF file, why don't I need to define an area corresponding to system memory?
