STM32F411 RTC Second Interrupt
Posted: Thu Feb 09, 2017 12:03 pm
by Tabulous
Having trouble getting this working
So i init the wakeup like this
void clkInit( void )
    rtcGetTime( &RTCD1, &ts );
    rtcGetDtStructTm( &ts, &t );
    clk.sec = t.tm_sec;
    clk.min = t.tm_min;
    clk.hrs = t.tm_hour;
    clk.day = t.tm_mday;
    clk.mon = t.tm_mon + 1;
    clk.year = ( t.tm_year - 100 );
    /* set wakeup */
    wakeupspec.wutr = (( uint32_t )4) << 16;      /* select 1 Hz clock source */
    wakeupspec.wutr |= ( 1 );                       /* Period in seconds */
    rtcSTM32SetPeriodicWakeup( &RTCD1,
                               &wakeupspec );
then setup the exti to capture the interrupt.
static const EXTConfig extio = {
    {EXT_CH_MODE_DISABLED, NULL},
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART, extcb2}  // RTC_WAKEUP EVENT
void extioInit( void )
     * Activates the EXT driver.
    extStart( &EXTD1, &extio );
static RTCWakeup wakeupspec;
static void extcb2(EXTDriver *extp, expchannel_t channel)
    (void)extp;
    (void)channel;
    palTogglePad(GPIOE, GPIOE_GRN_LED);
    /* re-setup wakeup */
//    wakeupspec.wutr = (( uint32_t )4) << 16;      /* select 1 Hz clock source */
 //   wakeupspec.wutr |= ( 1 );                       /* Period in seconds */
 //   rtcSTM32SetPeriodicWakeup( &RTCD1,
  //                             &wakeupspec );
Does one need to reset any interrupt ? as all that is happening is the callback is firing very fast, and not at 1Hz as expected ?
Re: STM32F411 RTC Second Interrupt
Posted: Thu Feb 09, 2017 12:19 pm
EXT driver resets the EXTI bits, I am not sure if there is something to reset in the RTC.
Is it "very fast" or continuously? if just fast maybe there is a wrong RTC setup.
Posted: Thu Feb 09, 2017 12:26 pm
by Tabulous
found answer here
http://www.chibios.com/forum/viewtopic.php?f=16&t=3381
one needs to do this.....
RTC->ISR &= ~RTC_ISR_WUTF; // Clear Wakeup Flag
EXTI->PR &= ~(1 << 22); // Clear the pending flag
Posted: Thu Feb 09, 2017 12:41 pm
by Tabulous
Also worth nothing
the above will result in 2 second tick......... you need to minus one from the timer period.
Might be worth doing that in rtcSTM32SetPeriodicWakeup ?
i.e.
void rtcSTM32SetPeriodicWakeup(RTCDriver *rtcp, const RTCWakeup *wakeupspec) {
syssts_t sts;
/* Entering a reentrant critical zone.*/
sts = osalSysGetStatusAndLockX();
if (wakeupspec != NULL) {
osalDbgCheck((wakeupspec->wutr & 0xFFFF) > 0);
osalDbgCheck(wakeupspec->wutr != 0x30000);
rtcp->rtc->CR &= ~RTC_CR_WUTE;
while (!(rtcp->rtc->ISR & RTC_ISR_WUTWF))
rtcp->rtc->WUTR = (wakeupspec->wutr & 0xFFFF) - 1;
rtcp->rtc->CR = (wakeupspec->wutr >> 16) & 0x7;
rtcp->rtc->CR |= RTC_CR_WUTIE;
rtcp->rtc->CR |= RTC_CR_WUTE;
else {
rtcp->rtc->CR &= ~RTC_CR_WUTIE;
/* Leaving a reentrant critical zone.*/
osalSysRestoreStatusX(sts);
