New Member [Q] streamRead
robert_o
Been thanked: 6 times
Post by robert_o »
Hello everybody.
I am quite new to RTOS and ARM so maybe i have some dumb questions, i am not totally new to C Programming though. I am working with ChibiStudio (Version: Luna Service Release 2 (4.4.2) Build id: 20150219-0600) with a DISCOVERY F4 (STM32F407VGT). I used the Example RT-STM32F407_DISCOVERY_MEMS and started from there. I am very impressed how easy working with Chibios is. The documentation is very good. I started some days ago and after a lot of struggle with installing an IDE (i tried four) and then figuring out the driver libs (CUBE with HAL and SPL) trying some alternative libs without success (libopencm3, tilen majerle) i stumbled over Chibios and everything just worked - i love it :).
Concerning my Project:
i am building an analyzer for Engine control units (actually it is the third version) i use the internal DAC to generate a waveform which imitates the trigger wheel. It looks like this: (http://forums.pelicanparts.com/uploads1 ... 366968.jpg).
This waveform is generated with Matlab as an array with 7200 8bit values (0.1 degree resolution and two crank revolutions). I want to transmit this array to the ARM over USB-CDC and should have it in a variable (an array) in RAM. Is this possible with streamRead?
I already used streamWrite (the example from: ChibiOS_16.1.7\community\testhal\STM32\STM32F4xx\USB_HOST) an writing works fine with "streamWrite(&SDU1, buf, sizeof buf-1);".
I just can't find any example for read.
A little help would be appreciated.
best regards
Robert
Re: New Member [Q] streamRead
Under /testhal/STM32 you will find an USB_CDC demo that emulates a serial port over USR, note that the demo implements a shell, you may implement a new shell command that loads your data.
Then look for the DAC them, it shows how to stream a data array to the DAC.
Put the two demos together and you will have most of your application.
