GPT timer
Posted: Fri May 12, 2017 2:55 pm
by plamen
I try to measure the width of a pulse using a general purpose timer. The function is invoked as callback to the EXTD1 driver, triggers on EXTI2 event:
void _extIRQ(EXTDriver *extp, expchannel_t channel)
if (_edgeChange == 0) {
gptStartContinuous(&GPTD5, 0); //greatest possible reset value
_edgeChange = 1;
} else {
gptStopTimer(&GPTD5);
_klineCfg.speed = 1000000 / gptGetCounterX(&GPTD5);
I can't invoke neighter gptStartContinuous nor gptStartContinuousI -> assert of improper I class use. It looks working properly if I disable CH_DBG_ENABLE_CHECKS in chconf.h. Could you please advice what is the proper way to use gptStartContinuous ?
Re: GPT timer
Posted: Sat May 13, 2017 7:40 am
you need to use the I-class functions inside callbacks and ISRs AND you need to call them in between chSysLockFromISR()...chSysUnlockFromISR(). The state checker stops you if do it wrong.
In the RT reference manual there is a section "kernel concepts", read the paragraphs regarding system states and the picture with states.
Re: GPT timer
Posted: Sat May 13, 2017 6:26 pm
by plamen
Thanks!
