FatFS Topic is solved
steved
Has thanked: 12 times
Been thanked: 138 times
FatFS
Post by steved »
Happened to notice that V0.13 has just been released: http://elm-chan.org/fsw/ff/00index_e.html
steved
Re: FatFS
Post by steved »
There have been a few changes to the file layout, and all the configuration settings in ffconf.h are now prefixed 'FF'
The attached files reflect these changes, with no actual code changes. Compile OK; not tested yet
fatfs_bindings.zip
FatFS bindings updated for V0.13
(3.6 KiB) Downloaded 483 times
ffconf.zip
FatFS configuration file updated for V0.13
(3.72 KiB) Downloaded 474 times
steved
Re: FatFS
Post by steved »
Small update to the bindings to update a couple of definitions I missed the first time, and correct some typos.
fatfs_bindings.zip
(3.59 KiB) Downloaded 475 times
Re: FatFS
I integrated FatFS 0.13, I also added the 2 mini-patches published on the project pages. Both trunk and 17.6.x.
