Page 1 of 2
stm32l4 lptim1/2 support
Posted: Thu Jun 08, 2017 9:14 am
by vrollei
I have added support for stm32l4 lptim1/2. Is it possible to merge changes with main code?
Re: stm32l4 lptim1/2 support
Posted: Thu Jun 08, 2017 1:51 pm
Moving this topic in "small changes".
Posted: Fri Aug 25, 2017 11:35 pm
by geoffrey.brown
Have you used this in tickless mode for the system counter ? I have an application with extremely low power requirements and want to use tickless with one of the low-power stop modes in the idle thread hook. I can live with 32khz tick resolution, since all of the sleep times are on order of milliseconds.
Any advice would be welcome on how to proceed.
Geoffrey
Posted: Sat Aug 26, 2017 9:21 am
by vrollei
Hi, Geoffrey!
Check out
ST based on RTC.
and
power module.
Posted: Sat Aug 26, 2017 1:16 pm
by geoffrey.brown
Thanks ! Your RTC code gave me a pretty clear idea about how to proceed. It's clear a general solution on power management is complex, but fortunately my application is simple enough that I can forgo that pain and use the idle thread hooks.
Geoffrey
Posted: Sun Sep 24, 2017 4:15 pm
The patch does not apply on trunk.
In general, when adding data in registry:
1) It must be added to all devices in the same registry file.
2) It must be added to all registries or drivers would get "undefined macro".
Posted: Sun Sep 24, 2017 5:12 pm
by vrollei
ok, will fix it.
Posted: Sun Sep 24, 2017 5:38 pm
Just a note, I merged the changes to stm32_tim.h, no need to redo that.
Posted: Mon Sep 25, 2017 12:19 pm
by vrollei
STM32F7 has LPTIM1 but without dedicated interrupt vector (use EXTI line).
What is the best way to define this type of LPTIM in registry file?
Posted: Mon Sep 25, 2017 12:52 pm
Uhm, good question...
What about having on all platforms:
#define STM32_LPTIM1_HANDLER Vectorxx
#define STM32_LPTIM1_NUMBER yy
On those that require an EXTI initialization add:
#define STM32_LPTIM1_EXTI_LINE zz
The drivers can check for STM32_LPTIM1_EXTI_LINE presence and initialize EXTI before enabling the NVIC vector. This could be used in general for all peripherals connected to EXTI.
