m25q STM32F746-DISCO example project (QSPI-N25Q128)
cpu20
Been thanked: 2 times
Post by cpu20 »
I have taken the QSPI-N25Q128 example project from the STM32L4xx and changed it so it works for the STM32F746-DISCO platform.
For now the pins are set manually in the main file, but I also attached a changed board.h file for the STM32F746-DISCO. If that board file is used then the pin configurations are done automatically and the configuration can be removed from the main file.
I have tested the program and it works perfectly for me.
Note that when using the m25q-driver on the M7-platform the QSPI uses DMA so the cache coherency problem pops up again. (Some minor fixes need to be made to the m25q-driver to work perfectly for the M7-platform, see this thread)
I hope the project is helpful for some people :)
ChibiOS_N25Q128_Example_STM32F7.zip
(12.49 KiB) Downloaded 580 times
QSPI_pin_changes.zip
(13.02 KiB) Downloaded 1731 times
