SPI_CR1_CPOL not working on STM32F427
Posted: Tue Aug 01, 2017 10:45 pm
by becafuel
I have a board that is using a F427ZIT and I want to read data from the MCP3204 chip (this is an ADC). This chip is using mode (1,1).
So, I configure my config this way :
uint16_t CR1 = SPI_CR1_BR_2 | SPI_CR1_SSI | SPI_CR1_MSTR | SPI_CR1_SPE | SPI_CR1_CPOL | SPI_CR1_CPHA;
  SPIConfig spi2_cfg =
     NULL,
     GPIOE,                                          /*   port of CS on Socket #2   */
     GPIOE_CS2,                                      /*   pin of CS    */
     CR1,
    0
Unfortunately, here is what I get :
And here is what I should get (got this using NETMF) :
Is there something I am doing wrong ? With the SPI_CR1_CPOL bit set, the clock line should be high, to me. Here it is low.
If I try Mode (0,0) then I get values back but those are wrong.
Regards,
________
Christophe
Re: SPI_CR1_CPOL not working on STM32F427
Posted: Thu Aug 03, 2017 2:18 pm
by becafuel
Nobody has any clue ? :?
Posted: Thu Aug 03, 2017 5:34 pm
You are initializing a field of a presumably constant structure using a variable.
Posted: Thu Aug 03, 2017 6:23 pm
by becafuel
What is the point ? I do not understand what can go wrong with this ?
The same exact code does work on a F429 iDiscovery and if I set the value directly in the struct it does not work either on the F427 :
SPIConfig spi5_cfg =
     NULL,
     SPI_CR1_SSI | SPI_CR1_MSTR | SPI_CR1_SPE | SPI_CR1_CPOL | SPI_CR1_CPHA,
    0
Posted: Thu Aug 03, 2017 7:32 pm
Remove this:
The driver handles those bits internally.
Posted: Fri Aug 04, 2017 10:47 am
by becafuel
Unfortunately, this does not change anything :(
The clock line is still held low.
Posted: Fri Aug 04, 2017 3:42 pm
You should verify that:
1) Registers are setup as expected after spiStart().
2) That the behavior is not the expected one from the STM32 Reference Manual.
