Send Repeated Start condition over i2c
Posted: Mon Aug 07, 2017 7:09 pm
by ep.hobbyiest
I am using STM32F103xx processor. I am using I2C driver for temp. sensor and eeprom as well. But i am confused to use start condition over i2c.
which API i can use for that.
I am using chibi studio 17.7 and chibi os 3. I have configured i2c1 for that (PB6 and PB7).
right now, processor is getting stuck at i2c read function only. (i think because i missed this repeated start condition).
Re: Send Repeated Start condition over i2c
Posted: Tue Aug 08, 2017 5:34 pm
by ep.hobbyiest
if i don't give timeout that is TIME_INFINITE then it get stuck i2cMasterReceiveTimeout function.
When i give timeout then i gets some value 21845 (0x5555).
static const I2CConfig i2cfg1 = {
    OPMODE_I2C,
    400000,
    FAST_DUTY_CYCLE_2,
void initI2cc(void)
  palSetPadMode(GPIOB, 6, PAL_MODE_STM32_ALTERNATE_OPENDRAIN);
  palSetPadMode(GPIOB, 7, PAL_MODE_STM32_ALTERNATE_OPENDRAIN);
  i2cStart(&I2CD1, &i2cfg1);
uint16_t readObjectTemp(uint8_t reg, uint16_t *dat)
  uint32_t tmo;
  tmo = MS2ST(4);
  uint8_t data[3];
  MSG_TIMEOUT == i2cMasterReceiveTimeout(&I2CD1, MLX90614_ADD,
                          data, 3, tmo)
  *dat = (data[1]<<8) | data[0];
I got I2C error as 4 that is I2C_ACK_FAILURE.
When i compile and checked wuth arduino then it was working fine with the same setup.
1.8 Kohm pull up is provided.
>epy.
Posted: Wed Aug 09, 2017 8:44 am
by steved
I don't think you need to worry about the repeated start condition; that's handled automatically (I assume; and I've never found it to be an issue when talking to I2C devices).
Favourite problem when getting started is specifying the I2C address properly. It's a 7-bit value, which some APIs expect to be in bits 1..7 of a byte. Chibi expects it to be in bits 0..6.
Do you have pullups on both of SDA and SCL?
I don't know that particular sensor; do you have to send it a command value of some sort before it will return data? If so, use i2cMasterTransmitTimeout() to send data then get a response in the same transaction.
Posted: Thu Aug 17, 2017 7:23 pm
by ep.hobbyiest
Yes. Now it is working with the same way. pull up went wrong.
