Goldbull board
Posted: Fri Nov 24, 2017 10:36 am
by Eddie
I bought this interesting board.
http://www.hotmcu.com/stm32f107vct6-dev ... p-114.html
I made board files and a demo project. Can it be included in the repository?
Files in Attachment.
Re: Goldbull board
Posted: Fri Nov 24, 2017 10:39 am
Could you try to not have a separate demo? in trunk there is an "unified" demo that you could use: RT-STM32-LWIP-FATFS-USB. You need to add the makefile and the configuration files, follow the pattern.
I am trying to reduce the total number of projects in the distribution, most of them are clones with little changes.
Re: Goldbull board
Posted: Fri Nov 24, 2017 10:44 am
by Eddie
Ok, I will try to create a unified demo.
Re: Goldbull board
Posted: Fri Nov 24, 2017 11:04 am
by Eddie
I was looking at a unified demo and I see the little problem. Unified demo uses SDC driver, GoldBull needs MMC driver. This will require a change in the main program.
Or you have any other suggestions.
Eddie
Re: Goldbull board
Posted: Fri Nov 24, 2017 11:09 am
hi,
You could put the driver initialization in a conditional block depending if HAL_USE_SDC is enabled or not.
Re: Goldbull board
Posted: Fri Nov 24, 2017 5:10 pm
by Eddie
ok, unified demo created..
Tested on Olimex E407 and Goldbull F107 :)
Re: Goldbull board
Posted: Fri Dec 01, 2017 10:19 am
Code merged with few changes, I cannot test on the goldbull board however.
Re: Goldbull board
Posted: Fri Dec 01, 2017 1:44 pm
by Eddie
I test the goldbull in the afternoon and write the result.
Eddie
Re: Goldbull board
Posted: Fri Dec 01, 2017 4:21 pm
by Eddie
demo for Goldbull working without problems :)
Eddie
