Small addon to modify variables
robert_o
Been thanked: 6 times
Post by robert_o »
I often need to change variables via shell and it is a little annoing that there is no increase or decrease with just one button. I wrote a little function which does that. No need to patch anything just add the shell function to your shell command list.
For now there are four different functions (one for 16 and 32bit, signed and unsigned) other types are easily added.
Features:
+ increases by one
- decreases by one
u increases by 10
d decreases by 10
U increases by 100
D decreases by 100
* multiplies by 10
/ divides by 10
x exits
other modifiers are also easily added
Example:
#include "ch.h"
#include "chprintf.h" //to get rid of compiler warnings
#include "stdlib.h" //to get rid of compiler warnings
#include "shell.h"
uint16_t one = 10;
int16_t two = -22;
uint32_t three = 0xffffffff;
int32_t four = -645599;
/* Command line related.                                                     */
#define SHELL_WA_SIZE   THD_WORKING_AREA_SIZE(2048)
//#define TEST_WA_SIZE    THD_WORKING_AREA_SIZE(256)
void shellModifyu16(BaseSequentialStream *chp, uint16_t * modify_p) {
  chprintf(chp, "Welcome to modify u16\r\n");
  chprintf(chp, "press '+' to increase one, '-' to decrease one \r\n");
  chprintf(chp, "'u' to increase 10, 'd' to decrease 10 \r\n");
  chprintf(chp, "'U' to increase 100, 'D' to decrease 100 \r\n");
  chprintf(chp, "'*' to multiply with 10, '/' to divide by 10 \r\n");
  chprintf(chp, "press 'x' to exit \r\n");
  chprintf(chp, "Status of var is: %u\r\n", *modify_p);
  while (true) {
    char c;
    if (chSequentialStreamRead(chp, (uint8_t *)&c, 1) == 0)
      chThdSleepMilliseconds(250);
    if (c == '+') {
      (*modify_p)++;
    if (c == '-') {
      (*modify_p)--;
    if (c == 'u') {
      *modify_p += 10;
    if (c == 'd') {
      *modify_p -= 10;
    if (c == 'U') {
      *modify_p += 100;
    if (c == 'D') {
      *modify_p -= 100;
    if (c == '*') {
      *modify_p *= 10;
    if (c == '/') {
      *modify_p /= 10;
    if (c == 'x') {
      chprintf(chp, "EXIT\r\n");
      return;
    if (c < 0x20)
      continue;
    chprintf(chp, "%u\r\n", *modify_p);
void shellModifys16(BaseSequentialStream *chp, int16_t * modify_p) {
  chprintf(chp, "Welcome to modify s16\r\n");
  chprintf(chp, "Status of var is: %d\r\n", *modify_p);
  while (true) {
    char c;
    if (c == '+') {
      (*modify_p)++;
    if (c == '-') {
      (*modify_p)--;
    if (c == 'u') {
      *modify_p += 10;
    if (c == 'd') {
      *modify_p -= 10;
    if (c == 'U') {
      *modify_p += 100;
    if (c == 'D') {
      *modify_p -= 100;
    if (c == '*') {
      *modify_p *= 10;
    if (c == '/') {
      *modify_p /= 10;
    if (c == 'x') {
      return;
    if (c < 0x20)
      continue;
    chprintf(chp, "%d\r\n", *modify_p);
void shellModifyu32(BaseSequentialStream *chp, uint32_t * modify_p) {
  chprintf(chp, "Welcome to modify u32\r\n");
  while (true) {
    char c;
    if (c == '+') {
      (*modify_p)++;
    if (c == '-') {
      (*modify_p)--;
    if (c == 'u') {
      *modify_p += 10;
    if (c == 'd') {
      *modify_p -= 10;
    if (c == 'U') {
      *modify_p += 100;
    if (c == 'D') {
      *modify_p -= 100;
    if (c == '*') {
      *modify_p *= 10;
    if (c == '/') {
      *modify_p /= 10;
    if (c == 'x') {
      return;
    if (c < 0x20)
      continue;
void shellModifys32(BaseSequentialStream *chp, int32_t * modify_p) {
  chprintf(chp, "Welcome to modify s32\r\n");
  while (true) {
    char c;
    if (c == '+') {
      (*modify_p)++;
    if (c == '-') {
      (*modify_p)--;
    if (c == 'u') {
      *modify_p += 10;
    if (c == 'd') {
      *modify_p -= 10;
    if (c == 'U') {
      *modify_p += 100;
    if (c == 'D') {
      *modify_p -= 100;
    if (c == '*') {
      *modify_p *= 10;
    if (c == '/') {
      *modify_p /= 10;
    if (c == 'x') {
      return;
    if (c < 0x20)
      continue;
static void cmd_status(BaseSequentialStream *chp, int argc, char *argv[]) {
  (void)argc;
  (void)* argv;
  chprintf(chp, "Status of Variables is: %u %d %u %d\r\n", one, two, three, four);
static void cmd_modify(BaseSequentialStream *chp, int argc, char *argv[]) {
  const char * const usage = "Usage: ch NUMBER\r\n";
  if (argc != 1) {
    chprintf(chp, usage);
    return;
  //uint16_t nr = (uint16_t)atoi(argv[0]);
  switch (atoi(argv[0])){
  case 0:
    shellModifyu16(chp, &one);
    break;
  case 1:
    shellModifys16(chp, &two);
    break;
  case 2:
    shellModifyu32(chp, &three);
   break;
  case 3:
    shellModifys32(chp, &four);
    break;
  default:
    chprintf(chp, "something went wrong\r\n");
    break;
static const ShellCommand commands[] = {
  {"stat", cmd_status},
  {"mod", cmd_modify},
  {NULL, NULL}
static const ShellConfig shell_cfg1 = {
  (BaseSequentialStream *)&SD1,
  commands
 * Blinker thread #1.
  (void)arg;
  while (true) {
    palSetPad(GPIOC, GPIOC_LED4);
    palClearPad(GPIOC, GPIOC_LED4);
 * Application entry point.
int main(void) {
  thread_t *shelltp = NULL;
   * System initializations.
   *   RTOS is active.
   * Shell manager initialization.
  shellInit();
   * PA9(TX) and PA10(RX) are routed to USART1.
  sdStart(&SD1, NULL);
  chprintf((BaseSequentialStream *)&SD1, "\033[2J\033[1;1H");
  chprintf((BaseSequentialStream *)&SD1, "ChibiOS Disco F100 Shell v0.2\r\n");
   * Creates the example threads.
  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
   * sleeping in a loop and check the button state, when the button is
   * pressed the test procedure is launched.
  while (true) {
    if (!shelltp) {
              /* Spawns a new shell.*/
              shelltp = shellCreate(&shell_cfg1, SHELL_WA_SIZE, NORMALPRIO+10);
      if (chThdTerminatedX(shelltp)) {
         /* Recovers memory of the previous shell.*/
         chThdRelease(shelltp);
         shelltp = NULL;
    chThdSleepMilliseconds(500);
