My fix in ChibiOS to make LWIP work
Laurent
Post by Laurent »
Hi
I was testing LWIP with ChibiOS (latest, 17.6.3) on a STM32F107 (Olimex STM32-P107 board, rev. B), and noticed that it didn't work quite well (couldn't ping the IP). After some random trials, I found that I needed to insert a delay right after the call to macStart (in lwipthread.c). After further investigation I came with the following fix at the beginning of the lwip_thread function:
  macStart(&ETHD1, &mac_config);
  /* begin fix */
  while (!ETHD1.link_up)
      macPollLinkStatus(&ETHD1);
      chThdSleepMilliseconds(100);
  /* end fix */
  netif_add(&thisif, &ip, &netmask, &gateway, NULL, ethernetif_init, tcpip_input);
It takes approximately 1.9 seconds to complete, which matches the delay I was using previously, and after that LWIP works perfectly.
The only problem is that I don't really understand what's going on, and I don't even know if this is really a fix. Can someone who understands LWIP and the ETH driver help me figure out a clean solution (or explain what happens, in case I already have the proper one)?
Thanks
Re: My fix in ChibiOS to make LWIP work
Could you give a try to the new lwIP in trunk code?
Laurent
Post by Laurent »
Thanks for your quick reply.
The current trunk seems to solve this particular problem, although it brings a new one: LWIP breaks on an assert as soon as a second TCP connection is made (the very first one works flawlessly apparently the first connection appears to break sometimes when receiving data).
Message:
pbuf_free: p->ref > 0
Call stack:
chSysHalt() at chsys.c:206 0x8013030
osalSysHalt.lto_priv.130() at osal.h:480 0x800ed0c
pbuf_free() at pbuf.c:747 0x800d4f8
prvxMBTCPPortReceive() at porttcp.c:290 0x8001334
tcp_process_refused_data() at tcp.c:1 331 0x800cc6a
tcp_fasttmr() at tcp.c:1 283 0x800cc04
tcp_tmr() at tcp.c:159 0x800db96
tcpip_tcp_timer() at timeouts.c:130 0x8007e9a
sys_check_timeouts() at timeouts.c:351 0x80081de
sys_timeouts_mbox_fetch() at timeouts.c:419 0x800828e
tcpip_thread.lto_priv.44() at tcpip.c:101 0x8002e64
_port_thread_start() at chcoreasm_v7m.S:119 0x8000256
The question is: is this caused by our interface layer or lwIP itself? I don't know how to approach this problem.
Laurent
Post by Laurent »
Nevermind, after investigating more I found that it was caused by another library that we use on top of LWIP.
