Page 1 of 2
Potential Design Pattern bug in Chibi Abstract peripheral interfaces
Posted: Sat Jan 27, 2018 3:45 am
by yusuf.husainy
Hi All,
We are working on writing external device drivers for certain Accelerometers/Gyros and Magnetometers using the abstract peripheral interface. While going through the design pattern(object oriented C having virtual function implementations), I found a potential flaw in the design pattern:
- ChibiOS version or subversion revision number : 17.6.2
- Compiler : gcc
- Platform and board : STM32, STM32L476RG-Nucleo
- Nature of the problem : Potential pointer dereference in polymorphic type inheritance models written in C for abstract peripheral devices
- Failure mode: Accessing polymorphic base class member data variables from a derived class object, using a base class pointer.
Eg: in the driver lis302dl.h, driver for accelerometer, the derived class of LIS302DLDriver from BaseAccelerometer, which in turn is derived from BaseSensor, has 3 virtual tables and 3 virtual pointers for each of them. So, if user creates an instance of LIS302DLDriver, typecasts it's address to a pointer of type BaseAccelerometer, then tries to access data members of BaseAccelerometer using that pointer, it would get garbage data since, the offset of the _base_accelerometer_data is actually the second virtual table of LIS302DLDriver declaration. (Luckily, for accelerometer abstract peripheral interface, there is no data for the base class, so this bug is missed.)
  • The following example code snippet wouldn't work(assume BaseSensor has a data variable called 'msg_t stateSensor') (just for illustration):
    In hal_sensors.h:
     * @brief   @p BaseSensor specific data.
     * @note    It is empty because @p BaseSensor is only an interface
     *          without implementation.
    #define _base_sensor_data \
      msg_t stateSensor;
    And in main.c:
      LIS302DLDriver derivedAccelerometerObject = {0};
      LIS302DLDriver * derivedAccelerometerPointer = &derivedAccelerometerObject;
      BaseSensor * baseAccelerometerPointer = (BaseSensor *)&derivedAccelerometerObject;
      derivedAccelerometerPointer->stateSensor = 1;
      msg_t stateViewedFromBaseAccelerometerPointer = baseAccelerometerPointer->stateSensor;
    In above snippet, stateViewedFromBaseAccelerometerPointer doesn't get updated with value of '1'.
  • A potential solution would be is to define class heirarchy of hal_sensors and it's derived forms as:
     * @brief   Base sensor class.
     * @details This class represents a generic blocking unbuffered sequential
     *          data stream.
    typedef struct {
      /** @brief Virtual Methods Table.*/
      const struct BaseSensorVMT *vptr;
      _base_sensor_data
    } BaseSensor;
     * @brief   Base accelerometer class.
     * @details This class represents a generic a generic accelerometer.
    typedef struct {
      const struct BaseAccelerometerVMT *vptr;
      _base_sensor_data
    } BaseAccelerometer;
     * @extends BaseAccelerometer
     * @brief   LIS302DL 3-axis accelerometer class.
     * @details This class extends @p BaseAccelerometer by adding physical
     *          driver implementation.
    struct LIS302DLDriver {
      /** @brief LIS302DL Virtual Methods Table. */
      const struct LIS302DLVMT *vptr;
      _lis302dl_data
    And then the macro definitions for function call helpers as:
     * @name    Macro Functions (BaseSensor)
     * @brief   Sensors get channels number.
     * @param[in] ip        pointer to a @p BaseSensor or derived class.
     * @return              The number of channels of the BaseSensor
     * @api
    #define sensorGetChannelNumber(ip) (ip)->vptr->get_channels_number(ip)
     * @brief   Sensors read raw data.
     * @param[in] dp        pointer to a data array.
     * @return              The operation status.
     * @retval MSG_OK       if the function succeeded.
     * @retval MSG_RESET    if one or more errors occurred.
     * @api
    #define sensorReadRaw(ip, dp) (ip)->vptr->read_raw(ip, dp)
    ...similarly for all derived classes of BaseSensor
Regards,
Yusuf Husainy
Re: Potential Design Pattern bug in Chibi Abstract peripheral interfaces
Posted: Sat Jan 27, 2018 4:17 am
by faisal
Another example of this design bug is if you use a JESD216 flash driver with MFS.
A BaseFlash instance looks like this:
typedef struct {
  _base_flash_methods_alone
  _base_flash_data
} BaseFlash;
A JESD216 instance looks like this:
typedef struct {
  _jesd216_flash_methods_alone
  _base_flash_data
} JESD215Flash;
As an example, when the MFS driver uses a m25q driver (which extends the JESD216 class), which is casted as a BaseFlash instance, the _base_flash_data (which constitutes a flash_state_t) will not be in the right place - rather _jesd216_flash_methods_alone is there! Is it a fluke that the demo is working, or do I have a fundamental misunderstanding?
Shouldn't the layering be something like this (incrementally adding to the structure, preserving the parent classes):
typedef struct {
  _animal_methods_alone
  _animal_data
} AnimalClass;
typedef struct {
  _animal_data
  _mammal_methods_alone
  _mammal_data
} MammalClass;
typedef struct {
  _animal_data
  _mammal_data
  _human_methods_alone
  _human_data
} HumanClass;
Posted: Sun Feb 04, 2018 10:38 am
About flash, thet code I am looking at is different from what you posted.
#define _jesd216_flash_methods                                              \
  _base_flash_methods                                                       \
struct JESD215FlashVMT {
#define _jesd216_flash_data                                                 \
  _base_flash_data
typedef struct {
  const struct JESD215FlashVMT *vmt;
  _jesd216_flash_data
} JESD215Flash;
The offset of _jesd216_flash_data does not change, there is always just one pointer before it.
RoccoMarco is looking into the other problem.
Posted: Sun Feb 04, 2018 12:38 pm
We identified various problems in EX related to multiple inheritance, we are working on it, thanks for finding.
Posted: Sun Feb 04, 2018 2:09 pm
by faisal
Giovanni wrote:Hi,
  _base_flash_data
typedef struct {
  _jesd216_flash_data
} JESD215Flash;
Yes, the text of the code is different. I posted the effective code after manually expanding the macros to make the bug I've identified clearer.
The issue is with where the base flash data is located in this particular example. In general, the way multiple inheritance is implemented is flawed, and I showed an example of how it could be done correctly using the Animal, Mammal, Human example.
Posted: Sun Feb 04, 2018 2:10 pm
by faisal
Giovanni wrote:Hi,
Cool, thanks for looking into it. Was worried if you would be able to address it before 18.x release.
Posted: Mon Feb 05, 2018 12:42 pm
by RoccoMarco
Fixed on trunk and backported to 17.6.4 as Bug #915.
Posted: Tue Feb 20, 2018 11:31 pm
by faisal
RoccoMarco wrote:Fixed on trunk and backported to 17.6.4 as Bug #915.
I believe there are still issues. Take the lis302dl driver as an example, which has been recently 'fixed'. A simple test you can do to see if the polymorphism will work, is to take the driver structure and cast it with the various base classes.
If you cast the LIS302DLDriver struct as a BaseAccelerometer, it will fail. Following the pattern of hal_sensors, and hal_accelerometer, the driver structure should look like this (remove the BaseSensorVMT and _base_sensor_data).
  const struct LIS302DLAccelerometerVMT *vmt_accelerometer;
  _lis302dl_data
I checked most of the ST devices, and this bug is in all of them.
Aside from the above bug fix, an improvement would be to just call the virtual method table 'vmt', instead of vmt_sensor/accelerometer, etc ... In fact, this is already the case in the flash peripheral classes.
Posted: Wed Feb 21, 2018 11:34 am
by RoccoMarco
Hello there,
thanks for reporting.
Discussing with Giovanni we noticed that there is a huge difference between flash and mems: here we have both polymorphism and multi-interface. Each MEMS indeed can suit more than an interface.
To address this difference we have added an additional API which give you the sub-interface pointer: a simple cast is not enough. I will provide some articles and example on play embedded soon.
Posted: Wed Feb 21, 2018 11:58 am
In the new scheme you cannot cast an object pointer to any of the ancestors, you need to cast the pointer to the VMT field and use that as reference. Each class now exports a "get" macro that does that.
#define getBaseAccelerometer(ip) ((BaseAccelerometer *)&(ip)->vmt_accelerometer)
I think there is still a problem too, taking the pointer to VMTs makes the data in the class inaccessible because the offset. also, the macro is not used by the invoker macros.
#define accelerometerGetAxesNumber(ip)                                      \
        (ip)->vmt_accelerometer->get_channels_number(ip)
It should be something like:
        getBaseAccelerometer(ip)->vmt_accelerometer->get_channels_number(ip)
This would mean that the accelerometer methods would only see the accelerometer data but not the lis302dl-specific data because the offset is shifted...
  /** @brief BaseSensor Virtual Methods Table. */
  const struct BaseSensorVMT *vmt_sensor;
  _base_sensor_data
  /** @brief BaseAccelerometer Virtual Methods Table. */
  _lis302dl_data
I don't see a solution right now... The requirement is that a device implementing multiple sensors must be accessible as instances of separate sensors.
