Test suite hangs at System tick counter functionnality
Posted: Mon Feb 12, 2018 9:54 pm
Hello Giovanny,
After running the test suite on Arduino Uno and Mega with success, I'm trying to run the test suite on xmega now.
The test suite hangs at the sequence 2 at test case 2.4
Here is the output of the test suite with the problem.
Can you please help me to understand what going on here so that I can solve the problem?
If you need mode details or the tested code I can provide it. It is not yet in the repository
*** ChibiOS/RT Test Suite
*** Compiled: Feb 12 2018 - 21:40:52
*** Platform: AVR XMEGA
*** Test Board: MT-DB-X4 board
=== Test Sequence 1 (Information)
--- Test Case 1.1 (Port Info)
--- Architecture: MegaAVR
--- Compiler: GCC 4.9.2
--- Port Info: None
--- Natural alignment: 1
--- Stack alignment: 1
--- Working area alignment: 1
--- Result: SUCCESS
--- Test Case 1.2 (Kernel Info)
--- Product: ChibiOS/RT
--- Stable Flag: 0
--- Version String: 5.0.0
--- Major Number: 5
--- Minor Number: 0
--- Patch Number: 0
--- Result: SUCCESS
--- Test Case 1.3 (Kernel Settings)
--- CH_CFG_ST_RESOLUTION: 16
--- CH_CFG_ST_FREQUENCY: 10000
--- CH_CFG_INTERVALS_SIZE: 16
--- CH_CFG_TIME_TYPES_SIZE: 16
--- CH_CFG_ST_TIMEDELTA: 0
--- CH_CFG_TIME_QUANTUM: 0
--- CH_CFG_MEMCORE_SIZE: 128
--- CH_CFG_NO_IDLE_THREAD: 0
--- CH_CFG_OPTIMIZE_SPEED: 1
--- CH_CFG_USE_TM: 0
--- CH_CFG_USE_REGISTRY: 1
--- CH_CFG_USE_WAITEXIT: 1
--- CH_CFG_USE_SEMAPHORES: 1
--- CH_CFG_USE_SEMAPHORES_PRI: 0
--- CH_CFG_USE_MUTEXES: 1
--- CH_CFG_USE_MUTEXES_RECURS: 0
--- CH_CFG_USE_CONDVARS: 1
--- CH_CFG_USE_CONDVARS_TIMEO: 1
--- CH_CFG_USE_EVENTS: 1
--- CH_CFG_USE_EVENTS_TIMEOUT: 1
--- CH_CFG_USE_MESSAGES: 1
--- CH_CFG_USE_MESSAGES_PRI: 0
--- CH_CFG_USE_MAILBOXES: 1
--- CH_CFG_USE_MEMCORE: 1
--- CH_CFG_USE_HEAP: 1
--- CH_CFG_USE_MEMPOOLS: 1
--- CH_CFG_USE_OBJ_FIFOS: 1
--- CH_CFG_USE_DYNAMIC: 0
--- CH_CFG_USE_FACTORY: 0
--- CH_CFG_FACTORY_MAX_NAMES_LENGTH: 8
--- CH_CFG_FACTORY_OBJECTS_REGISTRY: 1
--- CH_CFG_FACTORY_GENERIC_BUFFERS: 1
--- CH_CFG_FACTORY_SEMAPHORES: 1
--- CH_CFG_FACTORY_MAILBOXES: 1
--- CH_CFG_FACTORY_OBJ_FIFOS: 1
--- CH_DBG_STATISTICS: 0
--- CH_DBG_SYSTEM_STATE_CHECK: 0
--- CH_DBG_ENABLE_CHECKS: 0
--- CH_DBG_ENABLE_ASSERTS: 0
--- CH_DBG_TRACE_MASK: 255
--- CH_DBG_TRACE_BUFFER_SIZE: 128
--- CH_DBG_ENABLE_STACK_CHECK: 0
--- CH_DBG_FILL_THREADS: 0
--- CH_DBG_THREADS_PROFILING: 0
--- Result: SUCCESS
=== Test Sequence 2 (System layer and port interface)
--- Test Case 2.1 (System integrity functionality)
--- Result: SUCCESS
--- Test Case 2.2 (Critical zones functionality)
--- Result: SUCCESS
--- Test Case 2.3 (Interrupts handling functionality)
--- Result: SUCCESS
--- Test Case 2.4 (System Tick Counter functionality)
