Stop Mode for STM32F103
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Post by wurstnase »
Hi all,
I'm working on stop mode for stm32f103.
I found this thread and it was quit helpfull: viewtopic.php?t=3381#p28349
Thanks to chrismerck for sharing.
Instead of all the NOPs I found an interesting document from ARM:
http://infocenter.arm.com/help/index.js ... HFHJB.html
A DSB should be used after programming control registers, such as the System Control Register (SCR), when the side-effect is needed immediately. For example, a DSB is needed between the write to the SCS and the next operation if:
    the SLEEPDEEP setting in the SCR is changed, followed by either:
      enter sleep with WFI/WFE
      an exception exit, with Sleep-on-exit enabled.
In my example I configured a pin as external interrupt with the new pal event system. This works currently in tick-less mode.
Probably this is helpful for others, or maybe someone has a finding 8-)
void stopMode() {
  palEnableLineEvent(WAKEUP_LINE, PAL_EVENT_MODE_FALLING_EDGE); /* NC */
  SysTick->CTRL &= ~SysTick_CTRL_TICKINT_Msk;
  /* debugging */
  // DBGMCU->CR |= DBGMCU_CR_DBG_STOP | DBGMCU_CR_DBG_SLEEP | DBGMCU_CR_DBG_STANDBY;
  /* clear PDDS and LPDS bits */
  PWR->CR &= ~(PWR_CR_PDDS | PWR_CR_LPDS);
  /* set LPDS and clear  */
  PWR->CR |= PWR_CR_LPDS;
  /* enable wakeup pin */
  PWR->CSR |= PWR_CSR_EWUP;
  SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
  __DSB();
  __WFI();
  chSysLock();
  palDisableLineEventI(WAKEUP_LINE);
  SCB->SCR &= ~SCB_SCR_SLEEPDEEP_Msk;
  PWR->CR |= PWR_CR_CWUF;
  PWR->CR |= PWR_CR_CSBF;
  stm32_clock_init();
  SysTick->CTRL |= SysTick_CTRL_TICKINT_Msk;
  chSysUnlock();
