UART question.
Posted: Fri Mar 02, 2018 1:11 pm
by rew
* @brief Stops any ongoing receive operation.
* @note Stopping a receive operation also suppresses the receive callbacks.
* @param[in] uartp pointer to the @p UARTDriver object
* @return The number of data frames not received by the
* stopped receive operation.
* @retval 0 There was no receive operation in progress.
* @api
What happens when I start calling "uartStopReceive" and right at that moment, the buffer fills, i.e. 0 bytes remain to be put into the buffer?
Re: UART question.
Posted: Fri Mar 02, 2018 1:44 pm
It reads the DMA counter register, so you get zero.
Re: UART question.
Posted: Sun Mar 04, 2018 1:18 pm
by rew
Which is the same zero you would get when no operation was started. Wouldn't it be much better to have the return value be -1 when no operation was started? Choosing an "error code" from the range of valid "normal" return values is not such a good idea.
Re: UART question.
Posted: Sun Mar 04, 2018 3:59 pm
Moving in "change request".
Re: UART question.
Posted: Tue Mar 06, 2018 3:21 pm
by rew
FYI,
As with an example I found somewhere, (probably in haltest), my mainloop simply first stops the ongoing transfer, starts a new transfer in the "double buffer", and then processes whatever it got. So the first time around the loop, I get a "0" (no transfer started), which to the processing code means "got a full buffer!".
You might say: well first start the transfer then! Yeah. I can copy the code to start the first transfer. But then I've duplicated code leading to the real possibility of fixing a bug in one of them and not in the other.
When I started this thread, this was a bug, waiting to happen. It happened. My logfile now has:
001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00200 67 45 23 01 46 3d 36 0b fa ff ff ff 00 00 00 00
.. my data...
Re: UART question.
Posted: Wed Mar 07, 2018 10:53 am
I fixed it as bug #925 in trunk and 18.2.x.
