STM32L433 USB two PIN connection (PA11 & PA12)
Posted: Thu Apr 05, 2018 9:06 pm
by Skadi
I'm planning to establish an USB connection with a STM32L433. To keep the size of my PCB small, I want to use the LQFP-48 package. By having a look at my former projects using a STM32F407 discovery board, I noticed the pins PA2 and PA3 have to be remaped, as there alternate function includes USART_RX and USART_TX. The following lines are from ARMCM4-STM32F407-DISCOVERY-MEMS:
 * Activates the serial driver 2 using the driver default configuration.
 * PA2(TX) and PA3(RX) are routed to USART2.
sdStart(&SD2, NULL);
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
So my question is, do I need four pins to establish an USB connection (PA2, PA3, PA11, PA12). By remapping PA2 and PA3, I think this two pins can not be used as GPIO pins e.g. as an INPUT ot OUTPUT.
So is there a possebility to establish the USB connection only with PA11 and PA12, as it is shown in the datasheet in appendix A.1? I haven't found an example without the pin remapping. If not, I have to use an other package, because I need this two additional pins.
BR
Re: STM32L433 USB two PIN connection (PA11 & PA12)
Posted: Thu Apr 05, 2018 10:23 pm
Never tried it...
Posted: Fri Apr 06, 2018 10:04 am
by Skadi
thank you for your reply. I will make a further research. If I can manage a "two pin" connection, I will post my solution.
BR
Posted: Sat Apr 07, 2018 10:06 am
by rew
For USB you just need PA11 and PA12. Two pins, not more. There is something called a "physical layer", that says things about drive strength of the pins on the CPU. The "special pads" that have the right specs for USB are those marked "PA11" and "PA12". No other pin on the CPU can take that function because it doesn't have the hardware to do the right drive strength tricks. So while normally you'd switch a pin to AF mode and select the right AF to enable a module to use a pin, in this case, once you enable the USB module, PA11 and PA12 automatically are "hijacked" by the USB module. input/output mode or AF doesn't matter.
Posted: Sun Apr 15, 2018 11:36 pm
by Skadi
Hi rew,
thank you for your answer. I know, theortically I only need PA11 and PA12 to create an USB connection. I also know, that the controller has an internal PHY, enabling a USB FULL SPEED connetion (for HIGH SPEED an external PHY is required).
It is clear for me, that I have to configure PA11 and PA12 with their alternate function (10). I was just confused by the code snippet I already posted.
This code is from the RMCM4-STM32F407-DISCOVERY-MEMS example, and for me it looks like PA2 and PA3 have to be configured to PAL_MODE_ALTERNATE(7) to establish an USB connection.
However, I managed to create an USB connection without setting e.g. PA2 and PA3 to their alternate function. Therefor I had a look to the USB example in chibios182\testhal\STM32\STM32F4xx\USB_CDC_IAD.
To be sure everything really works as desired :D, I configured the pins PA2, PA3, PA15 (USART2_TX/RX), PA9, PA10, PB6, PB7 (USART1_TX/RX) and PB10, PB11 (USART3_TX/RX) as input or output pins, after the USB connection is started. Everything works fine, so far. So it seems the code example in chibios182\testhal\STM32\STM32F4xx\USB_CDC_IAD doesn't require any further alternate pin configurations, by means of an additional USART.
BR
Posted: Mon Apr 16, 2018 9:02 am
by rew
On older chips the USB would take over the pin without further involvement from you. It seems that USB is now a proper AF. So you need to set PA11 and PA12 to AF10 to enable USB.
You do NOT need to configure PA2 and PA3 to AF7 to enable USB. There are several reasons for this.
1) These pins have nothing to do with USB.
2) You can use them for whatever you want. USART if you want (AF7) but also TIM2 or simply GPIO.
Maybe the example demos that you can use them for serial communication, but it has nothing to do with USB on the other pins.
you have several USART modules inside your CPU. They have NOTHING to do with the USB module. They are completely independent.
