Having issues with usb otgv1 on STM32F723
Posted: Thu Jul 19, 2018 3:45 pm
I am using STM32F723 in one of our application which utilizes it to provide USB 2.0 device. I am using the HAL provided by chibiOS.
One of the benefits of STM32F723 is the built-in PHY for USB. The chibi HAL/LLD does not support this chip yet, so I made few changes to HAL/LLD (copied from the cubeMX library) after which, I am able to use the USB stack provided by chibi.
But I am having trouble when at some points in time, the code gets stuck in USB core reset loop when it calls:
usbStart() -> usb_lld_start()->otg_core_reset()->
I have attached hal_usb_lld.c with all the changes that I have made.
The behavior is a bit strange.
The cubeMX code works without issues. With the debugger and without the debugger.
When I run chibi code (with debugger) right after using cubeMX code (no power cycle in between), chibi code works fine.
If I power cycle the board after that, chibi code would not work, both in hardware and with the debugger.
This happens on couple of boards only. The rest of them work fine. Feels as if some default content is not set correctly.
Would appreciate if anyone can provide me with pointers on where to start looking.
AQ
while ((otgp->GRSTCTL & GRSTCTL_CSRST) != 0) //gets stuck on this lineI have attached hal_usb_lld.c with all the changes that I have made.
AQ
ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
* @file OTGv1/hal_usb_lld.c
* @brief STM32 USB subsystem low level driver source.
* @addtogroup USB
#include <string.h>
#include "hal.h"
#if HAL_USE_USB || defined(__DOXYGEN__)
/* Driver local definitions. */
#define TRDT_VALUE_FS 5
#define TRDT_VALUE_HS 9
#define EP0_MAX_INSIZE 64
#define EP0_MAX_OUTSIZE 64
#if STM32_OTG_STEPPING == 1
#if defined(BOARD_OTG_NOVBUSSENS)
#define GCCFG_INIT_VALUE (GCCFG_NOVBUSSENS | GCCFG_VBUSASEN | \
GCCFG_VBUSBSEN | GCCFG_PWRDWN)
#else
#define GCCFG_INIT_VALUE (GCCFG_VBUSASEN | GCCFG_VBUSBSEN | \
GCCFG_PWRDWN)
#elif STM32_OTG_STEPPING == 2
#define GCCFG_INIT_VALUE GCCFG_PWRDWN
#else
#define GCCFG_INIT_VALUE (GCCFG_VBDEN | GCCFG_PWRDWN)
/* Driver exported variables. */
/** @brief OTG_FS driver identifier.*/
#if STM32_USB_USE_OTG1 || defined(__DOXYGEN__)
USBDriver USBD1;
/** @brief OTG_HS driver identifier.*/
#if STM32_USB_USE_OTG2 || defined(__DOXYGEN__)
USBDriver USBD2;
/* Driver local variables and types. */
* @brief EP0 state.
* @note It is an union because IN and OUT endpoints are never used at the
* same time for EP0.
static union {
* @brief IN EP0 state.
USBInEndpointState in;
* @brief OUT EP0 state.
USBOutEndpointState out;
} ep0_state;
* @brief Buffer for the EP0 setup packets.
static uint8_t ep0setup_buffer[8];
* @brief EP0 initialization structure.
static const USBEndpointConfig ep0config = {
USB_EP_MODE_TYPE_CTRL,
_usb_ep0setup,
_usb_ep0in,
_usb_ep0out,
0x40,
0x40,
&ep0_state.in,
&ep0_state.out,
1,
ep0setup_buffer
static const stm32_otg_params_t fsparams = {
STM32_USB_OTG1_RX_FIFO_SIZE / 4,
STM32_OTG1_FIFO_MEM_SIZE,
STM32_OTG1_ENDPOINTS
static const stm32_otg_params_t hsparams = {
STM32_USB_OTG2_RX_FIFO_SIZE / 4,
STM32_OTG2_FIFO_MEM_SIZE,
STM32_OTG2_ENDPOINTS
/* Driver local functions. */
static void otg_core_reset(USBDriver *usbp) {
stm32_otg_t *otgp = usbp->otg;
osalSysPolledDelayX(32);
/* Core reset and delay of at least 3 PHY cycles.*/
otgp->GRSTCTL = GRSTCTL_CSRST;
osalSysPolledDelayX(18);
/* Wait AHB idle condition.*/
while ((otgp->GRSTCTL & GRSTCTL_AHBIDL) == 0)
static void otg_disable_ep(USBDriver *usbp) {
unsigned i;
for (i = 0; i <= usbp->otgparams->num_endpoints; i++) {
otgp->ie[i].DIEPCTL = 0;
otgp->ie[i].DIEPTSIZ = 0;
otgp->ie[i].DIEPINT = 0xFFFFFFFF;
otgp->oe[i].DOEPCTL = 0;
otgp->oe[i].DOEPTSIZ = 0;
otgp->oe[i].DOEPINT = 0xFFFFFFFF;
otgp->DAINTMSK = DAINTMSK_OEPM(0) | DAINTMSK_IEPM(0);
static void otg_rxfifo_flush(USBDriver *usbp) {
otgp->GRSTCTL = GRSTCTL_RXFFLSH;
while ((otgp->GRSTCTL & GRSTCTL_RXFFLSH) != 0)
/* Wait for 3 PHY Clocks.*/
static void otg_txfifo_flush(USBDriver *usbp, uint32_t fifo) {
otgp->GRSTCTL = GRSTCTL_TXFNUM(fifo) | GRSTCTL_TXFFLSH;
while ((otgp->GRSTCTL & GRSTCTL_TXFFLSH) != 0)
* @brief Resets the FIFO RAM memory allocator.
* @param[in] usbp pointer to the @p USBDriver object
* @notapi
static void otg_ram_reset(USBDriver *usbp) {
usbp->pmnext = usbp->otgparams->rx_fifo_size;
* @brief Allocates a block from the FIFO RAM memory.
* @param[in] size size of the packet buffer to allocate in words
* @notapi
static uint32_t otg_ram_alloc(USBDriver *usbp, size_t size) {
uint32_t next;
next = usbp->pmnext;
usbp->pmnext += size;
osalDbgAssert(usbp->pmnext <= usbp->otgparams->otg_ram_size,
"OTG FIFO memory overflow");
return next;
* @brief Writes to a TX FIFO.
* @param[in] fifop pointer to the FIFO register
* @param[in] buf buffer where to copy the endpoint data
* @param[in] n maximum number of bytes to copy
* @notapi
static void otg_fifo_write_from_buffer(volatile uint32_t *fifop,
const uint8_t *buf,
size_t n) {
osalDbgAssert(n > 0, "is zero");
while (true) {
*fifop = *((uint32_t *)buf);
if (n <= 4) {
break;
n -= 4;
buf += 4;
* @brief Reads a packet from the RXFIFO.
* @param[out] buf buffer where to copy the endpoint data
* @param[in] n number of bytes to pull from the FIFO
* @param[in] max number of bytes to copy into the buffer
* @notapi
static void otg_fifo_read_to_buffer(volatile uint32_t *fifop,
uint8_t *buf,
size_t n,
size_t max) {
uint32_t w = 0;
size_t i = 0;
while (i < n) {
if ((i & 3) == 0){
w = *fifop;
if (i < max) {
*buf++ = (uint8_t)w;
w >>= 8;
i++;
* @brief Incoming packets handler.
* @notapi
static void otg_rxfifo_handler(USBDriver *usbp) {
uint32_t sts, cnt, ep;
/* Popping the event word out of the RX FIFO.*/
sts = usbp->otg->GRXSTSP;
/* Event details.*/
cnt = (sts & GRXSTSP_BCNT_MASK) >> GRXSTSP_BCNT_OFF;
ep = (sts & GRXSTSP_EPNUM_MASK) >> GRXSTSP_EPNUM_OFF;
switch (sts & GRXSTSP_PKTSTS_MASK) {
case GRXSTSP_SETUP_DATA:
otg_fifo_read_to_buffer(usbp->otg->FIFO[0], usbp->epc[ep]->setup_buf,
cnt, 8);
break;
case GRXSTSP_SETUP_COMP:
break;
case GRXSTSP_OUT_DATA:
usbp->epc[ep]->out_state->rxbuf,
cnt,
usbp->epc[ep]->out_state->rxsize -
usbp->epc[ep]->out_state->rxcnt);
usbp->epc[ep]->out_state->rxbuf += cnt;
usbp->epc[ep]->out_state->rxcnt += cnt;
break;
case GRXSTSP_OUT_COMP:
break;
case GRXSTSP_OUT_GLOBAL_NAK:
break;
default:
break;
* @brief Outgoing packets handler.
* @param[in] ep endpoint number
* @notapi
static bool otg_txfifo_handler(USBDriver *usbp, usbep_t ep) {
/* The TXFIFO is filled until there is space and data to be transmitted.*/
while (true) {
uint32_t n;
/* Transaction end condition.*/
if (usbp->epc[ep]->in_state->txcnt >= usbp->epc[ep]->in_state->txsize) {
#if 1
usbp->otg->DIEPEMPMSK &= ~DIEPEMPMSK_INEPTXFEM(ep);
return true;
/* Number of bytes remaining in current transaction.*/
n = usbp->epc[ep]->in_state->txsize - usbp->epc[ep]->in_state->txcnt;
if (n > usbp->epc[ep]->in_maxsize)
n = usbp->epc[ep]->in_maxsize;
/* Checks if in the TXFIFO there is enough space to accommodate the
next packet.*/
if (((usbp->otg->ie[ep].DTXFSTS & DTXFSTS_INEPTFSAV_MASK) * 4) < n)
return false;
#if STM32_USB_OTGFIFO_FILL_BASEPRI
__set_BASEPRI(CORTEX_PRIO_MASK(STM32_USB_OTGFIFO_FILL_BASEPRI));
otg_fifo_write_from_buffer(usbp->otg->FIFO[ep],
usbp->epc[ep]->in_state->txbuf,
n);
usbp->epc[ep]->in_state->txbuf += n;
usbp->epc[ep]->in_state->txcnt += n;
__set_BASEPRI(0);
* @brief Generic endpoint IN handler.
* @notapi
static void otg_epin_handler(USBDriver *usbp, usbep_t ep) {
uint32_t epint = otgp->ie[ep].DIEPINT;
otgp->ie[ep].DIEPINT = epint;
if (epint & DIEPINT_TOC) {
/* Timeouts not handled yet, not sure how to handle.*/
if ((epint & DIEPINT_XFRC) && (otgp->DIEPMSK & DIEPMSK_XFRCM)) {
/* Transmit transfer complete.*/
USBInEndpointState *isp = usbp->epc[ep]->in_state;
if (isp->txsize < isp->totsize) {
/* In case the transaction covered only part of the total transfer
then another transaction is immediately started in order to
cover the remaining.*/
isp->txsize = isp->totsize - isp->txsize;
isp->txcnt = 0;
osalSysLockFromISR();
usb_lld_start_in(usbp, ep);
osalSysUnlockFromISR();
else {
/* End on IN transfer.*/
_usb_isr_invoke_in_cb(usbp, ep);
if ((epint & DIEPINT_TXFE) &&
(otgp->DIEPEMPMSK & DIEPEMPMSK_INEPTXFEM(ep))) {
#if 0
/* The thread is made ready, it will be scheduled on ISR exit.*/
usbp->txpending |= (1 << ep);
otgp->DIEPEMPMSK &= ~(1 << ep);
osalThreadResumeI(&usbp->wait, MSG_OK);
#else
/* TX FIFO empty or emptying.*/
otg_txfifo_handler(usbp, ep);
* @brief Generic endpoint OUT handler.
* @notapi
static void otg_epout_handler(USBDriver *usbp, usbep_t ep) {
uint32_t epint = otgp->oe[ep].DOEPINT;
/* Resets all EP IRQ sources.*/
otgp->oe[ep].DOEPINT = epint;
if ((epint & DOEPINT_STUP) && (otgp->DOEPMSK & DOEPMSK_STUPM)) {
/* Setup packets handling, setup packets are handled using a
specific callback.*/
_usb_isr_invoke_setup_cb(usbp, ep);
if ((epint & DOEPINT_XFRC) && (otgp->DOEPMSK & DOEPMSK_XFRCM)) {
USBOutEndpointState *osp;
/* OUT state structure pointer for this endpoint.*/
osp = usbp->epc[ep]->out_state;
/* EP0 requires special handling.*/
if (ep == 0) {
#if defined(STM32_OTG_SEQUENCE_WORKAROUND)
/* If an OUT transaction end interrupt is processed while the state
machine is not in an OUT state then it is ignored, this is caused
on some devices (L4) apparently injecting spurious data complete
words in the RX FIFO.*/
if ((usbp->ep0state & USB_OUT_STATE) == 0)
return;
if (((osp->rxcnt % usbp->epc[ep]->out_maxsize) == 0) &&
(osp->rxsize < osp->totsize)) {
osp->rxsize = osp->totsize - osp->rxsize;
osp->rxcnt = 0;
usb_lld_start_out(usbp, ep);
return;
/* End on OUT transfer.*/
_usb_isr_invoke_out_cb(usbp, ep);
* @brief Isochronous IN transfer failed handler.
* @notapi
static void otg_isoc_in_failed_handler(USBDriver *usbp) {
usbep_t ep;
for (ep = 0; ep <= usbp->otgparams->num_endpoints; ep++) {
if (((otgp->ie[ep].DIEPCTL & DIEPCTL_EPTYP_MASK) == DIEPCTL_EPTYP_ISO) &&
((otgp->ie[ep].DIEPCTL & DIEPCTL_EPENA) != 0)) {
/* Endpoint enabled -> ISOC IN transfer failed */
/* Disable endpoint */
otgp->ie[ep].DIEPCTL |= (DIEPCTL_EPDIS | DIEPCTL_SNAK);
while (otgp->ie[ep].DIEPCTL & DIEPCTL_EPENA)
/* Flush FIFO */
otg_txfifo_flush(usbp, ep);
/* Prepare data for next frame */
#if 0
/* Pump out data for next frame */
#else
* @brief Isochronous OUT transfer failed handler.
* @notapi
static void otg_isoc_out_failed_handler(USBDriver *usbp) {
usbep_t ep;
if (((otgp->oe[ep].DOEPCTL & DOEPCTL_EPTYP_MASK) == DOEPCTL_EPTYP_ISO) &&
((otgp->oe[ep].DOEPCTL & DOEPCTL_EPENA) != 0)) {
/* Endpoint enabled -> ISOC OUT transfer failed */
/* FIXME: Core stucks here */
/*otgp->oe[ep].DOEPCTL |= (DOEPCTL_EPDIS | DOEPCTL_SNAK);
while (otgp->oe[ep].DOEPCTL & DOEPCTL_EPENA)
/* Prepare transfer for next frame */
* @brief OTG shared ISR.
* @notapi
static void usb_lld_serve_interrupt(USBDriver *usbp) {
uint32_t sts, src;
sts = otgp->GINTSTS;
sts &= otgp->GINTMSK;
otgp->GINTSTS = sts;
/* Reset interrupt handling.*/
if (sts & GINTSTS_USBRST) {
#if 0
/* Resetting pending operations.*/
usbp->txpending = 0;
/* Default reset action.*/
_usb_reset(usbp);
/* Preventing execution of more handlers, the core has been reset.*/
return;
/* Wake-up handling.*/
if (sts & GINTSTS_WKUPINT) {
/* If clocks are gated off, turn them back on (may be the case if
coming out of suspend mode).*/
if (otgp->PCGCCTL & (PCGCCTL_STPPCLK | PCGCCTL_GATEHCLK)) {
/* Set to zero to un-gate the USB core clocks.*/
otgp->PCGCCTL &= ~(PCGCCTL_STPPCLK | PCGCCTL_GATEHCLK);
/* Clear the Remote Wake-up Signaling.*/
otgp->DCTL &= ~DCTL_RWUSIG;
_usb_wakeup(usbp);
/* Suspend handling.*/
if (sts & GINTSTS_USBSUSP) {
#if 0
/* Default suspend action.*/
_usb_suspend(usbp);
/* Enumeration done.*/
if (sts & GINTSTS_ENUMDNE) {
/* Full or High speed timing selection.*/
if ((otgp->DSTS & DSTS_ENUMSPD_MASK) == DSTS_ENUMSPD_HS_480) {
otgp->GUSBCFG = (otgp->GUSBCFG & ~(GUSBCFG_TRDT_MASK)) |
GUSBCFG_TRDT(TRDT_VALUE_HS);
else {
GUSBCFG_TRDT(TRDT_VALUE_FS);
/* SOF interrupt handling.*/
if (sts & GINTSTS_SOF) {
_usb_isr_invoke_sof_cb(usbp);
/* Isochronous IN failed handling */
if (sts & GINTSTS_IISOIXFR) {
otg_isoc_in_failed_handler(usbp);
/* Isochronous OUT failed handling */
if (sts & GINTSTS_IISOOXFR) {
otg_isoc_out_failed_handler(usbp);
/* RX FIFO not empty handling.*/
#if 0
if (sts & GINTSTS_RXFLVL) {
/* The interrupt is masked while the thread has control or it would
be triggered again.*/
otgp->GINTMSK &= ~GINTMSK_RXFLVLM;
#else
/* Performing the whole FIFO emptying in the ISR, it is advised to keep
this IRQ at a very low priority level.*/
if ((sts & GINTSTS_RXFLVL) != 0U) {
otg_rxfifo_handler(usbp);
/* IN/OUT endpoints event handling.*/
src = otgp->DAINT;
if (sts & GINTSTS_OEPINT) {
if (src & (1 << 16))
otg_epout_handler(usbp, 0);
if (src & (1 << 17))
otg_epout_handler(usbp, 1);
if (src & (1 << 18))
otg_epout_handler(usbp, 2);
if (src & (1 << 19))
otg_epout_handler(usbp, 3);
#if USB_MAX_ENDPOINTS >= 4
if (src & (1 << 20))
otg_epout_handler(usbp, 4);
#if USB_MAX_ENDPOINTS >= 5
if (src & (1 << 21))
otg_epout_handler(usbp, 5);
#if USB_MAX_ENDPOINTS >= 6
if (src & (1 << 22))
otg_epout_handler(usbp, 6);
#if USB_MAX_ENDPOINTS >= 7
if (src & (1 << 23))
otg_epout_handler(usbp, 7);
#if USB_MAX_ENDPOINTS >= 8
if (src & (1 << 24))
otg_epout_handler(usbp, 8);
if (sts & GINTSTS_IEPINT) {
if (src & (1 << 0))
otg_epin_handler(usbp, 0);
if (src & (1 << 1))
otg_epin_handler(usbp, 1);
if (src & (1 << 2))
otg_epin_handler(usbp, 2);
if (src & (1 << 3))
otg_epin_handler(usbp, 3);
if (src & (1 << 4))
otg_epin_handler(usbp, 4);
if (src & (1 << 5))
otg_epin_handler(usbp, 5);
if (src & (1 << 6))
otg_epin_handler(usbp, 6);
if (src & (1 << 7))
otg_epin_handler(usbp, 7);
if (src & (1 << 8))
otg_epin_handler(usbp, 8);
/* Driver interrupt handlers. */
* @brief OTG1 interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_OTG1_HANDLER) {
OSAL_IRQ_PROLOGUE();
usb_lld_serve_interrupt(&USBD1);
OSAL_IRQ_EPILOGUE();
* @brief OTG2 interrupt handler.
* @isr
OSAL_IRQ_HANDLER(STM32_OTG2_HANDLER) {
usb_lld_serve_interrupt(&USBD2);
/* Driver exported functions. */
* @brief Low level USB driver initialization.
* @notapi
void usb_lld_init(void) {
/* Driver initialization.*/
usbObjectInit(&USBD1);
#if 0
USBD1.wait = NULL;
USBD1.otg = OTG_FS;
USBD1.otgparams = &fsparams;
#if 0
#if defined(_CHIBIOS_RT_)
USBD1.tr = NULL;
/* Filling the thread working area here because the function
@p chThdCreateI() does not do it.*/
#if CH_DBG_FILL_THREADS
void *wsp = USBD1.wa_pump;
_thread_memfill((uint8_t *)wsp,
(uint8_t *)wsp + sizeof (USBD1.wa_pump),
CH_DBG_STACK_FILL_VALUE);
#endif /* CH_DBG_FILL_THREADS */
#endif /* defined(_CHIBIOS_RT_) */
usbObjectInit(&USBD2);
#if 0
USBD2.wait = NULL;
USBD2.otg = OTG_HS;
USBD2.otgparams = &hsparams;
#if 0
USBD2.tr = NULL;
void *wsp = USBD2.wa_pump;
(uint8_t *)wsp + sizeof (USBD2.wa_pump),
#if defined(NAS_BOARD_F7)
//AQTODO: place these defines appropriately
#if !defined (USB_HS_PHYC_TUNE_VALUE)
#define USB_HS_PHYC_TUNE_VALUE 0x00000F13U /*!< Value of USB HS PHY Tune */
#endif /* USB_HS_PHYC_TUNE_VALUE */
* @brief Enables control of a High Speed USB PHYs
* Init the low level hardware : GPIO, CLOCK, NVIC...
* @param USBx : Selected device
* @retval HAL status
static uint32_t USB_HS_PHYCInit(void)
uint32_t count = 0;
/* Enable LDO */
USB_HS_PHYC->USB_HS_PHYC_LDO |= USB_HS_PHYC_LDO_ENABLE;
/* wait for LDO Ready */
while((USB_HS_PHYC->USB_HS_PHYC_LDO & USB_HS_PHYC_LDO_STATUS) == RESET)
if (++count > 200000)
return -1;
/* Controls PHY frequency operation selection */
if (STM32_HSECLK == 12000000) /* HSE = 12MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x0 << 1);
else if (STM32_HSECLK == 12500000) /* HSE = 12.5MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x2 << 1);
else if (STM32_HSECLK == 16000000) /* HSE = 16MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x3 << 1);
else if (STM32_HSECLK == 24000000) /* HSE = 24MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x4 << 1);
else if (STM32_HSECLK == 25000000) /* HSE = 25MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x5 << 1);
else if (STM32_HSECLK == 32000000) /* HSE = 32MHz */
USB_HS_PHYC->USB_HS_PHYC_PLL = (uint32_t)(0x7 << 1);
/* Control the tuning interface of the High Speed PHY */
USB_HS_PHYC->USB_HS_PHYC_TUNE |= USB_HS_PHYC_TUNE_VALUE;
/* Enable PLL internal PHY */
USB_HS_PHYC->USB_HS_PHYC_PLL |= USB_HS_PHYC_PLL_PLLEN;
/* 2ms Delay required to get internal phy clock stable */
//HAL_Delay(2);
chSysPolledDelayX(TIME_MS2I(2)); //AQTODO: fix delay with proper timing
//chThdSleepMilliseconds(2);
return 0;
* @brief Configures and activates the USB peripheral.
* @note Starting the OTG cell can be a slow operation carried out with
* interrupts disabled, perform it before starting time-critical
* operations.
* @notapi
void usb_lld_start(USBDriver *usbp) {
if (usbp->state == USB_STOP) {
/* Clock activation.*/
if (&USBD1 == usbp) {
/* OTG FS clock enable and reset.*/
rccEnableOTG_FS(true);
rccResetOTG_FS();
/* Enables IRQ vector.*/
nvicEnableVector(STM32_OTG1_NUMBER, STM32_USB_OTG1_IRQ_PRIORITY);
/* - Forced device mode.
- USB turn-around time = TRDT_VALUE_FS.
- Full Speed 1.1 PHY.*/
otgp->GUSBCFG = GUSBCFG_FDMOD | GUSBCFG_TRDT(TRDT_VALUE_FS) |
GUSBCFG_PHYSEL;
/* 48MHz 1.1 PHY.*/
otgp->DCFG = 0x02200000 | DCFG_DSPD_FS11;
if (&USBD2 == usbp) {
/* OTG HS clock enable and reset.*/
rccEnableOTG_HS(true);
#if defined(NAS_BOARD_F7) // YH: OTG PHY available on NAS F7, not on eval.
rccEnableOTGPHYCEN(true);
//rccResetOTG_HS();
/* ULPI clock is managed depending on the presence of an external
PHY.*/
#if defined(BOARD_OTG2_USES_ULPI)
rccEnableOTG_HSULPI(true);
#else
rccEnableOTG_HSULPI(true); //AQTODO: need it for internal PHY
#else
/* Workaround for the problem described here:
http://forum.chibios.org/phpbb/viewtopic.php?f=16&t=1798.*/
rccDisableOTG_HSULPI();
nvicEnableVector(STM32_OTG2_NUMBER, STM32_USB_OTG2_IRQ_PRIORITY);
- USB turn-around time = TRDT_VALUE_HS or TRDT_VALUE_FS.*/
/* High speed ULPI PHY.*/
otgp->GUSBCFG = GUSBCFG_FDMOD | GUSBCFG_TRDT(TRDT_VALUE_HS) |
GUSBCFG_SRPCAP | GUSBCFG_HNPCAP;
#else
//otgp->GUSBCFG = GUSBCFG_FDMOD | GUSBCFG_TRDT(TRDT_VALUE_FS) |
// GUSBCFG_PHYSEL;
//AQTODO: changed config for HS PHY
otgp->GCCFG &= ~(GCCFG_PWRDWN);
/* Init The UTMI Interface */
otgp->GUSBCFG &= ~(GUSBCFG_TSDPS | GUSBCFG_ULPIFSLS | GUSBCFG_PHYSEL);
/* Select vbus source */
otgp->GUSBCFG &= ~(GUSBCFG_ULPIEVBUSD | GUSBCFG_ULPIEVBUSI);
/* Select UTMI Interace */
otgp->GUSBCFG &= ~GUSBCFG_ULPI_SEL;
otgp->GUSBCFG |= GUSBCFG_FDMOD | GUSBCFG_TRDT(TRDT_VALUE_HS) | //as per chibi
otgp->GCCFG |= GCCFG_PHYHSEN;
/* Enables control of a High Speed USB PHY */
USB_HS_PHYCInit();
#if STM32_USE_USB_OTG2_HS
/* USB 2.0 High Speed PHY in HS mode.*/
otgp->DCFG = 0x02200000 | DCFG_DSPD_HS;
#else
/* USB 2.0 High Speed PHY in FS mode.*/
otgp->DCFG = 0x02200000 | DCFG_DSPD_HS_FS;
#else
/* 48MHz 1.1 PHY.*/
//otgp->DCFG = 0x02200000 | DCFG_DSPD_FS11;
#if 0
/* Clearing mask of TXFIFOs to be filled.*/
/* PHY enabled.*/
otgp->PCGCCTL = 0;
/* VBUS sensing and transceiver enabled.*/
otgp->GOTGCTL = GOTGCTL_BVALOEN | GOTGCTL_BVALOVAL;
otgp->GCCFG = GCCFG_INIT_VALUE;
otgp->GCCFG = 0;
#else
//otgp->GCCFG = GCCFG_INIT_VALUE; //AQTODO: remove for testing
/* Soft core reset.*/
otg_core_reset(usbp);
/* Interrupts on TXFIFOs half empty.*/
otgp->GAHBCFG = 0;
/* Endpoints re-initialization.*/
otg_disable_ep(usbp);
/* Clear all pending Device Interrupts, only the USB Reset interrupt
is required initially.*/
otgp->DIEPMSK = 0;
otgp->DOEPMSK = 0;
otgp->DAINTMSK = 0;
if (usbp->config->sof_cb == NULL)
otgp->GINTMSK = GINTMSK_ENUMDNEM | GINTMSK_USBRSTM | GINTMSK_USBSUSPM |
GINTMSK_ESUSPM | GINTMSK_SRQM | GINTMSK_WKUM |
GINTMSK_IISOIXFRM | GINTMSK_IISOOXFRM;
else
GINTMSK_IISOIXFRM | GINTMSK_IISOOXFRM |
GINTMSK_SOFM;
/* Clears all pending IRQs, if any. */
otgp->GINTSTS = 0xFFFFFFFF;
#if 0
/* Creates the data pump thread. Note, it is created only once.*/
if (usbp->tr == NULL) {
thread_descriptor_t usbpump_descriptor = {
"usb_pump",
THD_WORKING_AREA_BASE(usbp->wa_pump),
THD_WORKING_AREA_END(usbp->wa_pump),
STM32_USB_OTG_THREAD_PRIO,
usb_lld_pump,
(void *)usbp
usbp->tr = chThdCreateI(&usbpump_descriptor);
chSchRescheduleS();
/* Global interrupts enable.*/
otgp->GAHBCFG |= GAHBCFG_GINTMSK;
* @brief Deactivates the USB peripheral.
* @notapi
void usb_lld_stop(USBDriver *usbp) {
/* If in ready state then disables the USB clock.*/
if (usbp->state != USB_STOP) {
/* Disabling all endpoints in case the driver has been stopped while
active.*/
#if 0
otgp->DAINTMSK = 0;
otgp->GAHBCFG = 0;
otgp->GCCFG = 0;
nvicDisableVector(STM32_OTG1_NUMBER);
rccDisableOTG_FS();
nvicDisableVector(STM32_OTG2_NUMBER);
rccDisableOTG_HS();
* @brief USB low level reset routine.
* @notapi
void usb_lld_reset(USBDriver *usbp) {
unsigned i;
/* Flush the Tx FIFO.*/
otg_txfifo_flush(usbp, 0);
/* Endpoint interrupts all disabled and cleared.*/
otgp->DIEPEMPMSK = 0;
/* All endpoints in NAK mode, interrupts cleared.*/
otgp->ie[i].DIEPCTL = DIEPCTL_SNAK;
otgp->oe[i].DOEPCTL = DOEPCTL_SNAK;
/* Resets the FIFO memory allocator.*/
otg_ram_reset(usbp);
/* Receive FIFO size initialization, the address is always zero.*/
otgp->GRXFSIZ = usbp->otgparams->rx_fifo_size;
otg_rxfifo_flush(usbp);
/* Resets the device address to zero.*/
otgp->DCFG = (otgp->DCFG & ~DCFG_DAD_MASK) | DCFG_DAD(0);
/* Enables also EP-related interrupt sources.*/
otgp->GINTMSK |= GINTMSK_RXFLVLM | GINTMSK_OEPM | GINTMSK_IEPM;
otgp->DIEPMSK = DIEPMSK_TOCM | DIEPMSK_XFRCM;
otgp->DOEPMSK = DOEPMSK_STUPM | DOEPMSK_XFRCM;
/* EP0 initialization, it is a special case.*/
usbp->epc[0] = &ep0config;
otgp->oe[0].DOEPTSIZ = DOEPTSIZ_STUPCNT(3);
otgp->oe[0].DOEPCTL = DOEPCTL_SD0PID | DOEPCTL_USBAEP | DOEPCTL_EPTYP_CTRL |
DOEPCTL_MPSIZ(ep0config.out_maxsize);
otgp->ie[0].DIEPTSIZ = 0;
otgp->ie[0].DIEPCTL = DIEPCTL_SD0PID | DIEPCTL_USBAEP | DIEPCTL_EPTYP_CTRL |
DIEPCTL_TXFNUM(0) | DIEPCTL_MPSIZ(ep0config.in_maxsize);
otgp->DIEPTXF0 = DIEPTXF_INEPTXFD(ep0config.in_maxsize / 4) |
DIEPTXF_INEPTXSA(otg_ram_alloc(usbp,
ep0config.in_maxsize / 4));
* @brief Sets the USB address.
* @notapi
void usb_lld_set_address(USBDriver *usbp) {
otgp->DCFG = (otgp->DCFG & ~DCFG_DAD_MASK) | DCFG_DAD(usbp->address);
* @brief Enables an endpoint.
* @notapi
void usb_lld_init_endpoint(USBDriver *usbp, usbep_t ep) {
uint32_t ctl, fsize;
/* IN and OUT common parameters.*/
switch (usbp->epc[ep]->ep_mode & USB_EP_MODE_TYPE) {
case USB_EP_MODE_TYPE_CTRL:
ctl = DIEPCTL_SD0PID | DIEPCTL_USBAEP | DIEPCTL_EPTYP_CTRL;
break;
case USB_EP_MODE_TYPE_ISOC:
ctl = DIEPCTL_SD0PID | DIEPCTL_USBAEP | DIEPCTL_EPTYP_ISO;
break;
case USB_EP_MODE_TYPE_BULK:
ctl = DIEPCTL_SD0PID | DIEPCTL_USBAEP | DIEPCTL_EPTYP_BULK;
break;
case USB_EP_MODE_TYPE_INTR:
ctl = DIEPCTL_SD0PID | DIEPCTL_USBAEP | DIEPCTL_EPTYP_INTR;
break;
default:
return;
/* OUT endpoint activation or deactivation.*/
otgp->oe[ep].DOEPTSIZ = 0;
if (usbp->epc[ep]->out_state != NULL) {
otgp->oe[ep].DOEPCTL = ctl | DOEPCTL_MPSIZ(usbp->epc[ep]->out_maxsize);
otgp->DAINTMSK |= DAINTMSK_OEPM(ep);
else {
otgp->oe[ep].DOEPCTL &= ~DOEPCTL_USBAEP;
otgp->DAINTMSK &= ~DAINTMSK_OEPM(ep);
/* IN endpoint activation or deactivation.*/
otgp->ie[ep].DIEPTSIZ = 0;
if (usbp->epc[ep]->in_state != NULL) {
/* FIFO allocation for the IN endpoint.*/
fsize = usbp->epc[ep]->in_maxsize / 4;
if (usbp->epc[ep]->in_multiplier > 1)
fsize *= usbp->epc[ep]->in_multiplier;
otgp->DIEPTXF[ep - 1] = DIEPTXF_INEPTXFD(fsize) |
DIEPTXF_INEPTXSA(otg_ram_alloc(usbp, fsize));
otgp->ie[ep].DIEPCTL = ctl |
DIEPCTL_TXFNUM(ep) |
DIEPCTL_MPSIZ(usbp->epc[ep]->in_maxsize);
otgp->DAINTMSK |= DAINTMSK_IEPM(ep);
else {
otgp->DIEPTXF[ep - 1] = 0x02000400; /* Reset value.*/
otgp->ie[ep].DIEPCTL &= ~DIEPCTL_USBAEP;
otgp->DAINTMSK &= ~DAINTMSK_IEPM(ep);
* @brief Disables all the active endpoints except the endpoint zero.
* @notapi
void usb_lld_disable_endpoints(USBDriver *usbp) {
/* Disabling all endpoints.*/
* @brief Returns the status of an OUT endpoint.
* @return The endpoint status.
* @retval EP_STATUS_DISABLED The endpoint is not active.
* @retval EP_STATUS_STALLED The endpoint is stalled.
* @retval EP_STATUS_ACTIVE The endpoint is active.
* @notapi
usbepstatus_t usb_lld_get_status_out(USBDriver *usbp, usbep_t ep) {
uint32_t ctl;
(void)usbp;
ctl = usbp->otg->oe[ep].DOEPCTL;
if (!(ctl & DOEPCTL_USBAEP))
return EP_STATUS_DISABLED;
if (ctl & DOEPCTL_STALL)
return EP_STATUS_STALLED;
return EP_STATUS_ACTIVE;
* @brief Returns the status of an IN endpoint.
* @notapi
usbepstatus_t usb_lld_get_status_in(USBDriver *usbp, usbep_t ep) {
uint32_t ctl;
(void)usbp;
ctl = usbp->otg->ie[ep].DIEPCTL;
if (!(ctl & DIEPCTL_USBAEP))
if (ctl & DIEPCTL_STALL)
* @brief Reads a setup packet from the dedicated packet buffer.
* @details This function must be invoked in the context of the @p setup_cb
* callback in order to read the received setup packet.
* @pre In order to use this function the endpoint must have been
* initialized as a control endpoint.
* @post The endpoint is ready to accept another packet.
* @param[out] buf buffer where to copy the packet data
* @notapi
void usb_lld_read_setup(USBDriver *usbp, usbep_t ep, uint8_t *buf) {
memcpy(buf, usbp->epc[ep]->setup_buf, 8);
* @brief Starts a receive operation on an OUT endpoint.
* @notapi
void usb_lld_start_out(USBDriver *usbp, usbep_t ep) {
uint32_t pcnt, rxsize;
USBOutEndpointState *osp = usbp->epc[ep]->out_state;
/* Transfer initialization.*/
osp->totsize = osp->rxsize;
if ((ep == 0) && (osp->rxsize > EP0_MAX_OUTSIZE))
osp->rxsize = EP0_MAX_OUTSIZE;
/* Transaction size is rounded to a multiple of packet size because the
following requirement in the RM:
"For OUT transfers, the transfer size field in the endpoint's transfer
size register must be a multiple of the maximum packet size of the
endpoint, adjusted to the Word boundary".*/
pcnt = (osp->rxsize + usbp->epc[ep]->out_maxsize - 1U) /
usbp->epc[ep]->out_maxsize;
rxsize = (pcnt * usbp->epc[ep]->out_maxsize + 3U) & 0xFFFFFFFCU;
/*Setting up transaction parameters in DOEPTSIZ.*/
usbp->otg->oe[ep].DOEPTSIZ = DOEPTSIZ_STUPCNT(3) | DOEPTSIZ_PKTCNT(pcnt) |
DOEPTSIZ_XFRSIZ(rxsize);
/* Special case of isochronous endpoint.*/
if ((usbp->epc[ep]->ep_mode & USB_EP_MODE_TYPE) == USB_EP_MODE_TYPE_ISOC) {
/* Odd/even bit toggling for isochronous endpoint.*/
if (usbp->otg->DSTS & DSTS_FNSOF_ODD)
usbp->otg->oe[ep].DOEPCTL |= DOEPCTL_SEVNFRM;
else
usbp->otg->oe[ep].DOEPCTL |= DOEPCTL_SODDFRM;
/* Starting operation.*/
usbp->otg->oe[ep].DOEPCTL |= DOEPCTL_EPENA | DOEPCTL_CNAK;
* @brief Starts a transmit operation on an IN endpoint.
* @notapi
void usb_lld_start_in(USBDriver *usbp, usbep_t ep) {
isp->totsize = isp->txsize;
if (isp->txsize == 0) {
/* Special case, sending zero size packet.*/
usbp->otg->ie[ep].DIEPTSIZ = DIEPTSIZ_PKTCNT(1) | DIEPTSIZ_XFRSIZ(0);
else {
if ((ep == 0) && (isp->txsize > EP0_MAX_INSIZE))
isp->txsize = EP0_MAX_INSIZE;
/* Normal case.*/
uint32_t pcnt = (isp->txsize + usbp->epc[ep]->in_maxsize - 1) /
/* TODO: Support more than one packet per frame for isochronous transfers.*/
usbp->otg->ie[ep].DIEPTSIZ = DIEPTSIZ_MCNT(1) | DIEPTSIZ_PKTCNT(pcnt) |
DIEPTSIZ_XFRSIZ(isp->txsize);
/* Odd/even bit toggling.*/
usbp->otg->ie[ep].DIEPCTL |= DIEPCTL_SEVNFRM;
else
usbp->otg->ie[ep].DIEPCTL |= DIEPCTL_SODDFRM;
usbp->otg->ie[ep].DIEPCTL |= DIEPCTL_EPENA | DIEPCTL_CNAK;
usbp->otg->DIEPEMPMSK |= DIEPEMPMSK_INEPTXFEM(ep);
* @brief Brings an OUT endpoint in the stalled state.
* @notapi
void usb_lld_stall_out(USBDriver *usbp, usbep_t ep) {
usbp->otg->oe[ep].DOEPCTL |= DOEPCTL_STALL;
* @brief Brings an IN endpoint in the stalled state.
* @notapi
void usb_lld_stall_in(USBDriver *usbp, usbep_t ep) {
usbp->otg->ie[ep].DIEPCTL |= DIEPCTL_STALL;
* @brief Brings an OUT endpoint in the active state.
* @notapi
void usb_lld_clear_out(USBDriver *usbp, usbep_t ep) {
usbp->otg->oe[ep].DOEPCTL &= ~DOEPCTL_STALL;
* @brief Brings an IN endpoint in the active state.
* @notapi
void usb_lld_clear_in(USBDriver *usbp, usbep_t ep) {
usbp->otg->ie[ep].DIEPCTL &= ~DIEPCTL_STALL;
#if 0
* @brief USB data transfer loop.
* @details This function must be executed by a system thread in order to
* make the USB driver work.
* @note The data copy part of the driver is implemented in this thread
* in order to not perform heavy tasks within interrupt handlers.
* @param[in] p pointer to the @p USBDriver object
* @special
void usb_lld_pump(void *p) {
USBDriver *usbp = (USBDriver *)p;
osalSysLock();
while (true) {
usbep_t ep;
uint32_t epmask;
/* Nothing to do, going to sleep.*/
if ((usbp->state == USB_STOP) ||
((usbp->txpending == 0) && !(otgp->GINTSTS & GINTSTS_RXFLVL))) {
otgp->GINTMSK |= GINTMSK_RXFLVLM;
osalThreadSuspendS(&usbp->wait);
osalSysUnlock();
/* Checks if there are TXFIFOs to be filled.*/
/* Empties the RX FIFO.*/
while (otgp->GINTSTS & GINTSTS_RXFLVL) {
epmask = (1 << ep);
if (usbp->txpending & epmask) {
bool done;
osalSysLock();
/* USB interrupts are globally *suspended* because the peripheral
does not allow any interference during the TX FIFO filling
operation.
Synopsys document: DesignWare Cores USB 2.0 Hi-Speed On-The-Go (OTG)
"The application has to finish writing one complete packet before
switching to a different channel/endpoint FIFO. Violating this
rule results in an error.".*/
otgp->GAHBCFG &= ~GAHBCFG_GINTMSK;
usbp->txpending &= ~epmask;
osalSysUnlock();
done = otg_txfifo_handler(usbp, ep);
osalSysLock();
if (!done)
otgp->DIEPEMPMSK |= epmask;
osalSysUnlock();
osalSysLock();
#endif /* HAL_USE_USB */
