[PATCH] make the shell work on NIL again
Posted: Mon Aug 27, 2018 1:57 pm
the shell doesn't compile in current trunk when used with NIL. The reason is that the chThdShouldTerminateX() and chEvtObjectInit() functions are missing.
I attached a patch to fix this. I made the whole shell thread exit logic optional with the SHELL_EXIT_ENABLED define. This is enabled by default on RT, but disabled on NIL.
I also added another patch with small output improvements.
Would it make sense to have a testcase with shell and NIL? For example in testhal or demos. Then it would be more easy to spot problems like this in the future.
Thanks for considering.
