[AVR][Demos]: Compilation error
Posted: Thu Mar 14, 2019 8:44 am
by tfAteba
Hello Giovanni,
I have just try to compile the AVR code since a while to see if every things is ok.
There is compilation error in all AVR/demo/ from ChibiOS_18.2.2 to ChibiOS_19.1.0 and I also think that it is the same problem in trunk, I did'nt test the trunk yet.
In halconf.h there is the defined macro:
#define PAL_USE_WAIT FALSE
That value cause problem. It must be TRUE in order to compile the code.
I will whange it in all halconf.h file after, but I want to know if normaly the code must also compile with the false value of this macros?
Here is the compilation traces:
Compiler Options
avr-gcc -c -mmcu=atmega2560 -I. -gdwarf-2 -DF_CPU=16000000UL -O2 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=build/lst/ -std=gnu11 -mrelax -fdata-sections -ffunction-sections -Wundef -MMD -MP -I. -I../../../os/license -I../../../os/common/ports/AVR -I../../../os/common/ports/AVR/compilers/GCC -I../../../os/rt/include -I../../../os/common/oslib/include -I../../../os/hal/include -I../../../os/hal/osal/rt -I../../../os/hal/ports/AVR/MEGA/ATMEGAxx -I../../../os/hal/ports/AVR/MEGA/LLD/ADCv1 -I../../../os/hal/ports/AVR/MEGA/LLD/EXTv1 -I../../../os/hal/ports/AVR/MEGA/LLD/GPIOv1 -I../../../os/hal/ports/AVR/MEGA/LLD/I2Cv1 -I../../../os/hal/ports/AVR/MEGA/LLD/SPIv1 -I../../../os/hal/ports/AVR/MEGA/LLD/TIMv1 -I../../../os/hal/ports/AVR/MEGA/LLD/USARTv1 -I../../../os/hal/ports/AVR/MEGA/LLD/USBv1 -I../../../os/hal/boards/ARDUINO_MEGA -I../../../os/various main.c -o main.o
Compiling chsys.c
Compiling chdebug.c
Compiling chtrace.c
Compiling chvt.c
Compiling chschd.c
Compiling chthreads.c
Compiling chregistry.c
Compiling chsem.c
Compiling chmtx.c
Compiling chcond.c
Compiling chevents.c
Compiling chmsg.c
Compiling chmboxes.c
Compiling chmemcore.c
Compiling chheap.c
Compiling chmempools.c
Compiling chcore.c
Compiling osal.c
Compiling hal.c
In file included from ../../../os/hal/include/hal_pal.h:174:0,
                 from ../../../os/hal/include/hal.h:129,
                 from ../../../os/hal/src/hal.c:25:
../../../os/hal/ports/AVR/MEGA/LLD/GPIOv1/hal_pal_lld.h:412:8: error: unknown type name ‘palevent_t’
 extern palevent_t _pal_events[16];
../../../os/common/ports/AVR/compilers/GCC/rules.mk:174: recipe for target 'build/obj/hal.o' failed
May be the current implementation must be updated?
Thanks for you advices.
Re: [AVR][Demos]: Compilation error
Posted: Thu Mar 14, 2019 11:31 am
Hi Theo,
I think some #if is needed in the LLD, probably it is missing this:
#if !defined(__DOXYGEN__)
#if (PAL_USE_WAIT == TRUE) || (PAL_USE_CALLBACKS == TRUE)
When in doubt look at template files under /os/pal/templates
Posted: Thu Mar 14, 2019 3:44 pm
by tfAteba
I will do that, thanks for your advices.
Posted: Sun Jan 19, 2020 3:16 pm
by tfAteba
Hello all,
Bug fixed,
Thanks Giovanni
