I was coding a driver to use SPIFFs on the SMT32F769I-DISCO board (has a MX25L51245G).
The WSPI driver, clock and DMA seem to be properly configured as I can successfully issue the RST enable (RSTEN) and RST commands.
When reading the device ID (RDID) I get unexpected values:
0x30
0x88
0x06
I've looked into the code of the macronix_mx25 driver and pretty much followed it.
Any hints on how I can degub this?
Thanks!
WSPI on STM32F769I Topic is solved
josesimoes
- Has thanked: 43 times
- Been thanked: 23 times
Re: WSPI on STM32F769I
It could be a lot of things, first thing, is the device in the expected state? (both interface and device using the same number of wires and clock mode).
josesimoes
I believe yes... the hardware is the STM board, so I trust it's working OK.
I've setup board.h to properly set the pin configs, including the AF values.
Also double check the commands against the ChibiOS driver.
josesimoes
Got it!
I went through all the possible configs and bumped into the clock setting.
I've added the following to mcuconf.h and it's now readin the expected IDs:
Suggestion maybe this config should be made more "visible"...
Thanks anyway for looking into this!
#define STM32_WSPI_QUADSPI1_PRESCALER_VALUE 2Suggestion maybe this config should be made more "visible"...
The device after a power up is in SPI mode unless it has been programmed using the non volatile control register. After a warm boot the device is in the state you left it because it does not take the same reset as the MCU.
