Using MMC driver with other SPI devices
Posted: Sun Jul 14, 2019 6:05 pm
I've got one of these TFT display breakout boards with SD card socket which shares same SPI interface with display. I already wrote driver which communicates with display and follows ChibiOS Hal communication with mutual exclusion:
The problem is that MMC driver encapsulates SPI calls and uses SPI without mutual exclusions and it doesn't follow calling sequence I described above (for example mmcConnect() just starts SPI driver, establishes connection with SD card and live driver in that state), which is a problem because I can't use same SPI for communication with different SPI devices at same bus. I can't use communication between mmcConnect() and mmcConnect() because I already have USB driver, which pulls data frequently and that will be performance penalty if I will connect and disconnect driver on every block reading and writing operation. Is there some workaround or fixes for my issue?
Best regards, Harry.
spiAcquireBus()
spiStart()
spiSelect()
//spiSend(), spiReceive() and spiExchange() calls
spiUnselect();
spiReleaseBus();
