Heap less space then expected
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Post by wurstnase »
I'm using the latest stable_19.1.x branch.
my code looks like:
#define ALLOC_SIZE 256
#define MB_BUFFER_SIZE 8
typedef struct {
    uint16_t size;
    uint8_t buf[ALLOC_SIZE - 2];
} uart_msg_t;
static memory_heap_t heap_reader;
static uart_msg_t heap_reader_buffer[MB_BUFFER_SIZE];
static THD_FUNCTION(uart_reader, arg) {
    (void)arg;
    static uart_msg_t *uart_msg, *uart_msg_new;
    chHeapObjectInit(&heap_reader, heap_reader_buffer,
                     sizeof(heap_reader_buffer));
    uart_msg = chHeapAlloc(&heap_reader, sizeof(uart_msg_t));
    while (true) {
        do_stuff();
        if (NULL == uart_msg)
        // breakpoint
I always jump in the breakpoint after 7 allocations. I expect it should hit it after 8 allocs.
Any hints are welcome.
Re: Heap less space then expected
Two points:
1) The heap allocator puts an 8 bytes header below each allocated block, you need to consider the overhead.
2) If you allocate objects of the same size, then a Pool is the preferred allocator (way way better in that scenario).
wurstnase
Post by wurstnase »
Ah ok. This wasn't obvious.
I already changed it to a pool after the post. But thanks for the hint.
