I looked at the documentation of the hal ADC Driver and some examples online and in the code examples and am confused by how to use the ADCConversionGroup.
In the hal_adc_lld.h it says there are 4 parameters in the struct:
105 /**
106 * @brief Conversion group configuration structure.
107 * @details This implementation-dependent structure describes a conversion
108 * operation.
109 * @note The use of this configuration structure requires knowledge of
110 * PLATFORM ADC cell registers interface, please refer to the PLATFORM
111 * reference manual for details.
112 */
113 typedef struct {
114 /**
115 * @brief Enables the circular buffer mode for the group.
116 */
117 bool circular;
118 /**
119 * @brief Number of the analog channels belonging to the conversion group.
120 */
121 adc_channels_num_t num_channels;
122 /**
123 * @brief Callback function associated to the group or @p NULL.
124 */
125 adccallback_t end_cb;
126 /**
127 * @brief Error callback or @p NULL.
128 */
129 adcerrorcallback_t error_cb;
130 /* End of the mandatory fields.*/
131 } ADCConversionGroup;In the example for the STM32F0xx ADC, there are 8 parameters in a struct:
* ADC conversion group.
* Mode: Linear buffer, 8 samples of 1 channel, SW triggered.
* Channels: IN10.
static const ADCConversionGroup adcgrpcfg1 = {
FALSE,
ADC_GRP1_NUM_CHANNELS,
NULL,
adcerrorcallback,
ADC_CFGR1_CONT | ADC_CFGR1_RES_12BIT, /* CFGR1 */
ADC_TR(0, 0), /* TR */
ADC_SMPR_SMP_1P5, /* SMPR */
ADC_CHSELR_CHSEL10 /* CHSELR */
* Mode: Continuous, 16 samples of 8 channels, SW triggered.
* Channels: IN10, IN11, Sensor, VRef.
static const ADCConversionGroup adcgrpcfg2 = {
TRUE,
ADC_GRP2_NUM_CHANNELS,
adccallback,
adcerrorcallback,
ADC_SMPR_SMP_28P5, /* SMPR */
ADC_CHSELR_CHSEL10 | ADC_CHSELR_CHSEL11 |
ADC_CHSELR_CHSEL16 | ADC_CHSELR_CHSEL17 /* CHSELR */
};In some forum posts here and guides on the internet I found them used with 11 parameters as well though; for example here:
FALSE, // circular buffer mode
IR_ADC_GRP1_NUM_CHANNELS, // number of the analog channels
NULL, // callback function
NULL, // error callback
0, // CR1
ADC_CR2_SWSTART, // CR2
ADC_SMPR1_SMP_AN11(ADC_SAMPLE_3) | ADC_SMPR1_SMP_AN14(ADC_SAMPLE_3) | ADC_SMPR1_SMP_AN15(ADC_SAMPLE_3),// sample times for channel 10-18
0,// sample times for channel 0-9
ADC_SQR1_NUM_CH(IR_ADC_GRP1_NUM_CHANNELS),// ADC SQR1 Conversion group sequence 13-16 + sequence length.
0, // ADC SQR2 Conversion group sequence 7-12
ADC_SQR3_SQ1_N(ADC_CHANNEL_IN11) | ADC_SQR3_SQ2_N(ADC_CHANNEL_IN14) | ADC_SQR3_SQ3_N(ADC_CHANNEL_IN15) // ADC SQR3 Conversion group sequence 1-6
};Another thing to add here is that it uses a completely different way to address the channels and set the sample rates, etc.
My question now is the following: Which of these is the "correct"/best usage of the ADCConversionGroup and why are there so many differences between the code examples, the documentation and code you find online?
Which is the preferred way of passing the channels, sample rates, etc?
And last but not least: For the above mentioned scenario, what would be the correct ADCConversionGroup?
