STM32F446 wrong PLLSAI source for CK48MSEL_PLLALT Topic is solved
heliochronix
Has thanked: 8 times
Been thanked: 6 times
Postby heliochronix » Wed Sep 25, 2019 6:41 pm
As of trunk@13027 I've discovered that STM32F446 should use PLLSAI_P_CLKOUT as its source when CK48MSEL is set to PLLALT. This differs from most of the other F4xx devices which use either PLLSAI_Q_CLKOUT or PLLI2S_Q_CLKOUT (which is what's currently coded), so this may require some slight changes t hal_lld.h and an addition to the stm32_registry.h entries to distinguish which source a given device uses.
I haven't yet had a chance to try my hand at implementing a fix, but I thought I would at least log the issue. My initial thought was to define the source in stm32_registry.h for each device, somewhat like these:
#define STM32_PLL48CLK_ALTSRC    STM32_PLLSAI_Q_CLKOUT
#define STM32_PLL48CLK_ALTSRC    STM32_PLLSAI_P_CLKOUT
#define STM32_PLL48CLK_ALTSRC    STM32_PLLI2S_Q_CLKOUT
then modify the code in hal_lld.h from
#elif STM32_CK48MSEL == STM32_CK48MSEL_PLLALT
#if STM32_RCC_CK48MSEL_USES_I2S
#define STM32_PLL48CLK              STM32_PLLI2S_Q_CLKOUT
#else
#define STM32_PLL48CLK              STM32_PLLSAI_Q_CLKOUT
#else
to something like
#define STM32_PLL48CLK              STM32_PLL48CLK_ALTSRC
#else
But I'm not sure if this would adversely affect things. Does this seem reasonable to you?
Has thanked: 876 times
Been thanked: 750 times
Re: STM32F446 wrong PLLSAI source for CK48MSEL_PLLALT
Postby Giovanni » Wed Sep 25, 2019 7:24 pm
It looks like a good idea, the F4 family is a mess second only to F0. It seems they learned the lesson with L0, L4+, G0 and G4.
FXCoder
Has thanked: 169 times
Been thanked: 121 times
Postby FXCoder » Wed Sep 25, 2019 9:40 pm
Should merge with the latest
fix for F413.
FYI I also have some upcoming registry changes to add some defines needed for an initial EFL driver for F4 (413 initially).
Bob
FXCoder
Postby FXCoder » Sat Sep 28, 2019 7:52 am
Below is proposed patch to handle:
#1 STM32_CK48MSEL variances of PLLI2S and PLLSAI configuration between F4 family members.
a) STM32_CK48MSEL_PLLALT now used to specify alt PLL (I2S or SAI) for 48MHz.
b) Deprecated unused defines STM32_HAS_RCC_CK48MSEL_I2S and STM32_HAS_RCC_CK48MSEL_SAI
#2 Add F4XX/F2XX STM32_FLASH_PSIZE definitions required for upcoming EFL driver (F413 version is WIP).
Tested on F413 at the moment.
Please review.
Bob
Index: os/hal/ports/STM32/STM32F4xx/hal_lld.h
--- os/hal/ports/STM32/STM32F4xx/hal_lld.h   (revision 12966)
+++ os/hal/ports/STM32/STM32F4xx/hal_lld.h   (working copy)
@@ -182,7 +182,8 @@
 #if STM32_HAS_RCC_CK48MSEL || defined(__DOXYGEN__)
 #if (STM32_CK48MSEL == STM32_CK48MSEL_PLL) || defined(__DOXYGEN__)
 #define STM32_PLL48CLK              (STM32_PLLVCO / STM32_PLLQ_VALUE)
-#elif STM32_CK48MSEL == STM32_CK48MSEL_PLLALT
+#elif STM32_CK48MSEL == STM32_CK48MSEL_PLLALT ||                            \
+      STM32_CK48MSEL == STM32_CK48MSEL_PLLI2S
 #else
Index: os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h
--- os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h   (revision 12966)
+++ os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h   (working copy)
@@ -1037,7 +1037,8 @@
 #endif /* !defined(STM32F4XX) */
- * @name    Maximum frequency thresholds and wait states for flash access.
+ * @name    Maximum frequency thresholds, wait states and
+ *          parallelism for flash access.
 #if defined(STM32F429_439xx) || defined(STM32F427_437xx) ||                 \
@@ -1053,6 +1054,7 @@
 #define STM32_6WS_THRESHOLD         0
 #define STM32_7WS_THRESHOLD         0
 #define STM32_8WS_THRESHOLD         0
+#define STM32_FLASH_PSIZE           2
 #elif (STM32_VDD >= 240) && (STM32_VDD < 270)
 #define STM32_0WS_THRESHOLD         24000000
 #define STM32_1WS_THRESHOLD         48000000
@@ -1063,6 +1065,7 @@
 #define STM32_6WS_THRESHOLD         168000000
 #define STM32_7WS_THRESHOLD         180000000
+#define STM32_FLASH_PSIZE           1
 #elif (STM32_VDD >= 210) && (STM32_VDD < 240)
 #define STM32_0WS_THRESHOLD         22000000
 #define STM32_1WS_THRESHOLD         44000000
@@ -1073,6 +1076,7 @@
 #define STM32_6WS_THRESHOLD         154000000
 #define STM32_7WS_THRESHOLD         176000000
 #define STM32_8WS_THRESHOLD         180000000
 #elif (STM32_VDD >= 180) && (STM32_VDD < 210)
 #define STM32_0WS_THRESHOLD         20000000
 #define STM32_1WS_THRESHOLD         40000000
@@ -1083,6 +1087,7 @@
 #define STM32_6WS_THRESHOLD         140000000
 #define STM32_7WS_THRESHOLD         168000000
+#define STM32_FLASH_PSIZE           0
 #else
 #error "invalid VDD voltage specified"
@@ -1098,6 +1103,7 @@
@@ -1108,6 +1114,7 @@
 #define STM32_0WS_THRESHOLD         18000000
 #define STM32_1WS_THRESHOLD         36000000
@@ -1118,6 +1125,7 @@
 #elif (STM32_VDD >= 170) && (STM32_VDD < 210)
 #define STM32_0WS_THRESHOLD         16000000
 #define STM32_1WS_THRESHOLD         32000000
@@ -1128,6 +1136,7 @@
 #define STM32_6WS_THRESHOLD         100000000
 #else
@@ -1143,6 +1152,7 @@
@@ -1153,6 +1163,7 @@
@@ -1163,6 +1174,7 @@
 #elif (STM32_VDD >= 171) && (STM32_VDD < 210)
@@ -1173,6 +1185,8 @@
 #else
@@ -1188,6 +1202,8 @@
@@ -1198,6 +1214,8 @@
@@ -1208,6 +1226,8 @@
@@ -1218,6 +1238,8 @@
 #else
@@ -1232,6 +1254,7 @@
 #define STM32_5WS_THRESHOLD         0
@@ -1241,6 +1264,7 @@
@@ -1250,6 +1274,7 @@
 #define STM32_5WS_THRESHOLD         108000000
 #define STM32_6WS_THRESHOLD         120000000
@@ -1259,6 +1284,8 @@
 #define STM32_5WS_THRESHOLD         96000000
 #define STM32_6WS_THRESHOLD         112000000
 #define STM32_7WS_THRESHOLD         120000000
 #else
Index: os/hal/ports/STM32/STM32F4xx/hal_lld_type2.h
--- os/hal/ports/STM32/STM32F4xx/hal_lld_type2.h   (revision 12966)
+++ os/hal/ports/STM32/STM32F4xx/hal_lld_type2.h   (working copy)
@@ -652,7 +652,8 @@
 #if defined(STM32F413xx)
@@ -666,6 +667,7 @@
@@ -676,6 +678,7 @@
@@ -686,6 +689,7 @@
@@ -696,9 +700,11 @@
 #else
+#define FLASH_SR_OPERR              FLASH_SR_SOP
 #endif /* defined(STM32F413xx) */
@@ -1169,6 +1175,12 @@
 #define STM32_PLLI2S_R_CLKOUT       (STM32_PLLI2SVCO / STM32_PLLI2SR_VALUE)
+ * @brief   PLLI2SP enable bit.
+ * @note    Always 0, there is no PLLI2SP.
+#define STM32_PLLI2SP               0
  * @brief   PLLSAI activation flag.
  * @note    Always FALSE, there is no PLLSAI.
Index: os/hal/ports/STM32/STM32F4xx/stm32_registry.h
--- os/hal/ports/STM32/STM32F4xx/stm32_registry.h   (revision 12966)
+++ os/hal/ports/STM32/STM32F4xx/stm32_registry.h   (working copy)
@@ -131,6 +131,7 @@
 #define STM32_HAS_RCC_I2SPLLSRC             FALSE
 #define STM32_HAS_RCC_CK48MSEL              TRUE
 #define STM32_RCC_CK48MSEL_USES_I2S         FALSE
+#define STM32_PLL48CLK_ALTSRC               STM32_PLLSAI_Q_CLKOUT
 #define STM32_TIMPRE_PRESCALE4              TRUE
 /* ADC attributes.*/
@@ -509,6 +510,7 @@
+#define STM32_PLL48CLK_ALTSRC               STM32_PLLSAI_P_CLKOUT
@@ -856,8 +858,6 @@
 #define STM32_HAS_RCC_PLLI2S                TRUE
 #define STM32_HAS_RCC_DCKCFGR               TRUE
 #define STM32_HAS_RCC_DCKCFGR2              FALSE
-#define STM32_HAS_RCC_CK48MSEL_I2S          FALSE
-#define STM32_HAS_RCC_CK48MSEL_SAI          FALSE
 #define STM32_HAS_RCC_I2SSRC                TRUE
 #define STM32_HAS_RCC_CK48MSEL              FALSE
@@ -1234,6 +1234,7 @@
 #define STM32_HAS_RCC_I2SPLLSRC             TRUE
 #define STM32_RCC_CK48MSEL_USES_I2S         TRUE
+#define STM32_PLL48CLK_ALTSRC               STM32_PLLI2S_Q_CLKOUT
 #define STM32_TIMPRE_PRESCALE4              FALSE
@@ -1618,6 +1619,7 @@
@@ -1949,6 +1951,7 @@
@@ -2248,12 +2251,11 @@
 #define STM32_HAS_RCC_PLLI2S                FALSE
 #define STM32_HAS_RCC_DCKCFGR2              TRUE
 #define STM32_HAS_RCC_I2SSRC                FALSE
@@ -2523,8 +2525,6 @@
 #define STM32_HAS_RCC_DCKCFGR               FALSE
heliochronix
Postby heliochronix » Tue Oct 01, 2019 12:02 am
It looks like the patch set never sets STM32_PLL48CLK to STM32_CK48MSEL_ALTSRC.
FXCoder
Postby FXCoder » Tue Oct 01, 2019 12:18 pm
Yes. The patch was taken from a diff of a local modified copy of ChibiOS by mistake.
This one is taken against trunk...
Index: hal_lld.h
--- hal_lld.h   (revision 13058)
+++ hal_lld.h   (working copy)
@@ -183,12 +183,8 @@
-#if STM32_RCC_CK48MSEL_USES_I2S
-#define STM32_PLL48CLK              STM32_PLLI2S_Q_CLKOUT
+#define STM32_PLL48CLK              STM32_PLL48CLK_ALTSRC
 #else
-#define STM32_PLL48CLK              STM32_PLLSAI_Q_CLKOUT
-#endif
-#else
 #error "invalid source selected for PLL48CLK clock"
 #else /* !STM32_HAS_RCC_CK48MSEL */
Index: hal_lld_type1.h
--- hal_lld_type1.h   (revision 13058)
+++ hal_lld_type1.h   (working copy)
 #else
 #else
 #else
 #else
 #else
Index: hal_lld_type2.h
--- hal_lld_type2.h   (revision 13058)
+++ hal_lld_type2.h   (working copy)
@@ -652,7 +652,8 @@
@@ -666,6 +667,7 @@
@@ -676,6 +678,7 @@
@@ -686,6 +689,7 @@
 #else
Index: stm32_registry.h
--- stm32_registry.h   (revision 13058)
+++ stm32_registry.h   (working copy)
@@ -131,6 +131,7 @@
@@ -509,6 +510,7 @@
@@ -856,8 +858,6 @@
Postby Giovanni » Sat Oct 05, 2019 2:21 pm
So the only needed patch is the last one posted?
FXCoder
Postby FXCoder » Sat Oct 05, 2019 2:27 pm
Correct.
I'll post the F412/413 EFL driver after a bit more testing.
The necessary additional flash parameter values are included in the above patch.
Bob
Postby Giovanni » Sun Oct 06, 2019 7:06 am
Fixed as bug #1049.
Thank you both for handling this, could you verify everything is fine (apparently it is on my side).
FXCoder
Postby FXCoder » Mon Oct 07, 2019 9:03 am
Builds and runs on F413 using PLL_I2S (specified as STM32_CK48MSEL_PLLALT) for clock source.
Heliochronix to confirm F446.
Bob
Return to “Bug Reports”
