UART driver & threads
sntnjrg
Has thanked: 18 times
Post by sntnjrg »
I have two threads that read from the serial port:
thread A:
uartStartReceive(&UARTD3, BUFFER_SIZE_A, rx_buffer_A);
thread B:
uartStartReceive(&UARTD2, BUFFER_SIZE_B, rx_buffer_B);
In both threads, after I run the uartStart() function, I start reading on both ports.
The ports are assigned the following callbacks:
UARTD3:
- callback txend1_cb: set A_txend1_cb() function.
- callback rxend_cb: set A_rxend_cb() function.
- callback rxerr_cb: set A_rxerr_cb() function.
- callback timeout_cb: set A_timeout_cb() function.
UARTD2:
- callback rxend_cb: set B_rxend_cb() function.
- callback rxerr_cb: set B_rxerr_cb() function.
- callback timeout_cb: set B_timeout_cb() function.
The thread A sends commands to a device and waits for a response. When I run thread B, I have observed that the response is lost.
I have checked that in the txend1_cb() callback the command has been sent but I never receive anything through the UARTD3 port. If I only execute thread A, I receive the response associated with the command that I sent.
Is this problem because I have different functions assigned to each callback?
Thank you
Re: UART driver & threads
Callback functions should not have an impact on UART operations, it must be something else.
I recommend to activate assertions and state checker in chconf.h and to compile using -O0 until the problem is cleared.
mikeprotts
Has thanked: 19 times
Been thanked: 31 times
Post by mikeprotts »
It may be worth using a diuagnostic rxchar callback in case it's a buffering issue. Possibly also worth reducing buffer size to less than the data size to ensure an end of buffer occurs.
Mike
sntnjrg
Post by sntnjrg »
After several tests, I have observed that the problem is when I set the transmission mode (wiring) in the device associated with the thread B. When I remove the wiring, everything works perfectly.
Thank you for the help.
