RTC on STM373 with Chibios 19.1
Posted: Mon Nov 04, 2019 8:45 am
I'm migrating projects from versions 17.6 and 18.2 to Chibios 19.1.
And i'm having some trouble...
All projects that use the STM32L496 migrated fine.
The ones that uses the STM32F373 with RTC support are complaining about a lot of things about the RTC.
These projects uses the internal RTC with external crystal.
And while compiling, i obtain the following type of errors:
For the migration, i compared/adapted all the common files (chconf.h, halconf.h makefile, mcuconf.h) against the ones in the testhal folder for the STM32F37x.
Then I tried to compile the HAL ADC driver demo for the 373, and it compiles fine.
But if i modify halconf.h, changing HAL_USE_RTC from FALSE to TRUE, i obtain similar errors.
Someone has some ideas of what can be wrong or missing ?
Thanks in advance.
Stephane
In file included from ../../chibios191/os/hal/include/hal_rtc.h:115:0,
from ../../chibios191/os/hal/include/hal.h:145,
from ../../chibios191/os/hal/src/hal_mmcsd.c:25:
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.h:54:38: warning: "STM32_RTC_STORAGE_SIZE" is not defined, evaluates to 0 [-Wundef]
#define RTC_HAS_STORAGE (STM32_RTC_STORAGE_SIZE > 0)
../../chibios191/os/hal/include/hal_rtc.h:131:6: note: in expansion of macro 'RTC_HAS_STORAGE'
#if (RTC_HAS_STORAGE == TRUE) || defined(__DOXYGEN__)
etc...
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:535:2: error: #error "missing required RTC handlers definitions in registry"
In file included from ../../chibios191/os/hal/ports/STM32/STM32F37x/hal_lld.h:996:0,
from ../../chibios191/os/hal/include/hal.h:118,
from ../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:29:
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c: In function 'rtc_lld_init':
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:585:31: error: 'STM32_RTC_ALARM_EXTI' undeclared (first use in this function); did you mean 'STM32_RTC_PRER_BITS'?
extiEnableGroup1(EXTI_MASK1(STM32_RTC_ALARM_EXTI) |
../../chibios191/os/hal/ports/STM32/LLD/EXTIv1/stm32_exti.h:105:44: note: in definition of macro 'EXTI_MASK1'
#define EXTI_MASK1(line) (uint32_t)(1U << (line))
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:585:31: note: each undeclared identifier is reported only once for each function it appears in
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:586:31: error: 'STM32_RTC_TAMP_STAMP_EXTI' undeclared (first use in this function); did you mean 'STM32_RTC_ALARM_EXTI'?
EXTI_MASK1(STM32_RTC_TAMP_STAMP_EXTI) |
Compiling hal_spi_lld.c
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:587:31: error: 'STM32_RTC_WKUP_EXTI' undeclared (first use in this function); did you mean 'STM32_RTC_ALARM_EXTI'?
EXTI_MASK1(STM32_RTC_WKUP_EXTI),
Compiling hal_st_lld.c
../../chibios191/os/hal/ports/STM32/LLD/RTCv2/hal_rtc_lld.c:591:3: warning: implicit declaration of function 'STM32_RTC_IRQ_ENABLE'; did you mean 'STM32_LPTIM_CR_ENABLE'? [-Wimplicit-function-declaration]
STM32_RTC_IRQ_ENABLE();
etc...
Thanks in advance.
Stephane
