CH_DBG_FILL_THREADS should fill the main stack Topic is solved
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Post by wurstnase »
currently only CH_DBG_ENABLE_STACK_CHECK will fill the main-stack.
Also
static inline stkalign_t *chThdGetWorkingAreaX(thread_t *tp)
should be available with CH_DBG_FILL_THREADS.
Re: CH_DBG_FILL_THREADS should fill the main stack
The main stack is not defined in the RTOS code, it is part of the normal C runtime because it is already in use upon main() function entry and before chSysInit() is called (you cannot clear a stack you are running on), the allocation is statically done in the linker file.
The fill options for system stacks are available in the startup file crt0xx.S:
- CRT0_STACKS_FILL_PATTERN
- CRT0_INIT_STACKS
