ChibiOS/RT
Posted: Tue Apr 14, 2020 5:07 pm
by vem
I have just merged the ChibiOS library ChRt onto my arduino libraries, and the library works fine, I was hoping that I will now be able to set the execution time for a task, as required by a real time system that a task must execute within a finite time. The code in the documantation that come close to this definition is below here, as it atleast say do _something(); should have been completed before the chThdSleepUntil(time) line, but this still does not address the issue, as acording to the documentation, it is possible that if the do_something(); execution time exceeds the set time for ChThdSleep(); the thread "would stay sleeping into chThdSleepUntil() until the (very far) specified instant in the future."
msg_t my_thread(void *param) {
systime_t time = chVTGetSystemTimeX(); // T0
while (true) {
time += MS2ST(1000); // Next deadline
do_something();
chThdSleepUntil(time);
Now my question is how to I set the deadline for the do_something(); ?
Re: ChibiOS/RT
Posted: Tue Apr 14, 2020 5:27 pm
Look into this function:
 * @brief   Suspends the invoking thread until the system time arrives to the
 *          specified value.
 * @note    The system time is assumed to be between @p prev and @p next
 *          else the call is assumed to have been called outside the
 *          allowed time interval, in this case no sleep is performed.
 * @see     chThdSleepUntil()
 * @param[in] prev      absolute system time of the previous deadline
 * @param[in] next      absolute system time of the next deadline
 * @return              the @p next parameter
 * @api
systime_t chThdSleepUntilWindowed(systime_t prev, systime_t next)
It allows to specify a time range, the sleep ends if the time is out of the "window", so if your do_something() exceeds the interval then the sleep is not performed.
Examples here: http://www.chibios.org/dokuwiki/doku.ph ... _threading
Re: ChibiOS/RT
Posted: Wed Apr 15, 2020 1:50 pm
by vem
Thank you very much! I appreciate your response. I will look more in the literature on Real-Time programming
My main concer is how do we restrict the do something(); ececution time to a finite number of choice, say 10ms for example.
Re: ChibiOS/RT
Posted: Wed Apr 15, 2020 2:36 pm
You need to add a check into your function internal loop and see if it should be interrupted. You can use this to keep a loop within a time window, add it to your conditions:
 * @brief   Checks if the current system time is within the specified time
 *          window.
 * @note    When start==end then the function returns always false because the
 *          time window has zero size.
 * @param[in] start     the start of the time window (inclusive)
 * @param[in] end       the end of the time window (non inclusive)
 * @retval true         current time within the specified time window.
 * @retval false        current time not within the specified time window.
 * @api
static inline bool chVTIsSystemTimeWithin(systime_t start, systime_t end) {
  return chTimeIsInRangeX(chVTGetSystemTime(), start, end);
Re: ChibiOS/RT
Posted: Wed Apr 15, 2020 9:11 pm
by steved
Another way to do what you want is to have a thread which waits on either an event (the thread-specific event flags are easiest to understand) or a semaphore.
Then set up a regular 'tick' from either one of the hardware timers (suggested if you are using short intervals; <100msec, say) or the Chibi event timer; the 'tick handler' simply sets the event flag or semaphore.
This avoids some of your concerns about the task overrunning, since the flag to trigger the next processing happens regardless. If it is critical that your task runs exactly once per tick, use a counting semaphore to trigger it. If you can live with missing the odd trigger should the task overrun, use the event flags.
