Running GPT-ADC example on STM32F746g-Discovery, I can't step into code while debugging
Abusous2000
Has thanked: 7 times
Post by Abusous2000 »
I have been chasing this issue for couple of days, and I found nothing about it. I hope you can help me.
When I run the GPT-ADC example on STM32F746g-Discovery (as-s without any change), I can't step-into code while debugging and when I do it always jumps to the DMA2 Stream 4 ISR. It should be noted that
- prior to starting the timer, the debugger works as expected, and this behavior happens only after the time is activated after calling gptStartContinuous(&GPTD4, 100); on line 176
- all is good if I port the example to STM32769i board.
I appreciate any feedback.
Many thank,
Abu al-Sous
PS. I am using the latest version of ChibiStudio & ChibiOS 20.x
Re: Running GPT-ADC example on STM32F746g-Discovery, I can't step into code while debugging
Frankly no idea, it is possible that the device does not suspend DMA/TIMs during debug so it gets flooded with DMA IRQs.
You should check the manual.
