how to synchronize the system clock
Posted: Thu Jul 02, 2020 9:00 am
by sntnjrg
I am studying how to synchronize the system clock from the date and time of a GNSS receiver.
RTC is synchronized it using this function from the IRQ:
* @brief Set current time.
* @note This function can be called from any context but limitations
* could be imposed by the low level implementation. It is
* guaranteed that the function can be called from thread
* context.
* @note The function can be reentrant or not reentrant depending on
* the low level implementation.
* @param[in] rtcp pointer to RTC driver structure
* @param[in] timespec pointer to a @p RTCDateTime structure
* @special
void rtcSetTime(RTCDriver *rtcp, const RTCDateTime *timespec)
The system clock is based on ticks. I'm a newbie. How can I synchronize it or estimate the correction factor to be applied to it?
Thanks you.
Re: how to synchronize the system clock
Posted: Thu Jul 02, 2020 10:01 am
Note that RTC and system clock are two separate things, system clock cannot be modified, it is meant to be a monotonic counter. What you may adjust is the RTC using that function you mentioned (better do that from a thread, not an ISR).
Posted: Thu Jul 02, 2020 2:30 pm
by sntnjrg
Hi Giovanni
If I use shared variables, to atomically access those variables:
- I use
chSysLockFromISR()/chSysUnlockFromISR() in ISR.
- I use
chSysLock()/chSysUnlock()) in thread.
Is that right?
I'm trying to calculate the factor based on the system clock ticks. In the GNSS receiver, I use the PPS signal output. This signal is generated every second. I define the following callback:
static volatile system_t tp;
static volatile float Tp;
static void pps_cb(void *arg) {
(void)arg;
chSysLockFromISR();
// Calculate the previous
tp = chVTGetSystemTimeX();
struct tm timp;
RTCDateTime rtc_dateTime;
uint32_t tv_msec;
rtcGetTime(&RTCD1, &rtc_dateTime);
rtcConvertDateTimeToStructTm(&rtc_dateTime, &timp, &tv_msec);
Tp = static_cast<float>(mktime(&timp)) + (static_cast<float>(tv_msec) / 1000);
chSysUnlockFromISR();
} // pps_cb
In the thread, I calculate the current time provided by the GNSS receiver, update the system clock and try to calculate the correction based on the current ticks:
T' = Tc + ((current_ticks - tc) * ((Tc-Tp)/(tc-tp)));
where:
Tc = timestamp in seconds when RTC was updated
tc = ticks when RTC was updated.
I have observed that Tc and Tp are always of the same value.
Could it be that I'm not atomically reading the values?
Thanks you.
Posted: Thu Jul 02, 2020 6:25 pm
by steved
Firstly, it appears you haven't registered Giovanni's point that the system clock and the RTC are two different things, and that you cannot adjust the system clock (it's derived from the CPU crystal, if any, and I'm pretty certain there's no method to fine tune the frequency).
So you can only adjust the RTC; it has an internal calibration register. And dependent on the device, the RTC often has a resolution of 1 second, although it may be possible to access a higher frequency internally.
The PPS tick is making life rather difficult for you, when compared with a time server which actually gives time of day; in the simplest system you could just update the RTC with the time.
So what you probably need to do is count input pulses over an extended period, compare it with the elapsed time according to the RTC over that period, then both update the current time on the RTC, and adjust the calibration register to slow down or speed up the RTC. The measurement period will need to be long enough to give a meaningful time difference - thousands of seconds, I would think.
The system clock should be a pretty stable frequency, so you could use it to measure the pulse input and the RTC timing.
Posted: Thu Jul 02, 2020 7:53 pm
sntnjrg wrote:Hi Giovanni
- I use chSysLockFromISR()/chSysUnlockFromISR() in ISR.
- I use chSysLock()/chSysUnlock()) in thread.
Is that right?
This is correct however note that from a critical section you can only call those functions with names terminated with X, I or S, this is an important point, see "function classes" in the documentation or in the book. rtcGetTime() is a special case and is allowed but it is not guaranteed to be allowed in any possible implementation, there is a note in the function docs.
In chconf.h you can enable assertions and the "state checker" it will catch invalid function calls and find a lot of possible problems.
