hal_buffer_queue : how to use it
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
I have to transmit fixed buffer size from dma ISR to thread, input_buffers_queue_t seems to be the appropriate tool.
In my application, after few iterations, it fails because of memory corruption, probably because of misuse. The only example of use i have found is in hal_serial_usb.
I have reproduced my problem with a very simple example with a writer and a reader in two thread, and it fails with the same symptoms.
what I do is (using ChibiOS 20.3.x) :
global var declaration :
#define BUFFER_SIZE 64U
#define QUEUE_LEN   32U
static uint8_t readWriteBuffer[BUFFER_SIZE * QUEUE_LEN];
static input_buffers_queue_t readWriteQueue;
initialization in main :
 ibqObjectInit(&readWriteQueue, false, readWriteBuffer,
      BUFFER_SIZE, QUEUE_LEN,
      NULL, NULL);
in writer thread :
  chSysLock();
    uint8_t * const qbuf = ibqGetEmptyBufferI(&readWriteQueue);
    if (qbuf != NULL) {
      memcpy(qbuf, source, BUFFER_SIZE);
      ibqPostFullBufferI(&readWriteQueue, BUFFER_SIZE);
    chSysUnlock();
in reader thread:
  uint8_t dest[BUFFER_SIZE];
  size_t cnt=0;
  while (true) {
    const msg_t n = ibqReadTimeout(&readWriteQueue, dest, sizeof(dest),
               TIME_INFINITE);
    // doing something with dest
    chDbgAssert(n != 0, "ibqReadTimeout");
it works for 29 iterations then i have memory corruption in ibqPostFullBufferI.
Any advice are welcome on the good way to correctly use buffer queue !
EDIT:
I have tried the zero copy read API with same problem :
in reader thread:
  while (true) {
    const msg_t status = ibqGetFullBufferTimeout(&readWriteQueue, TIME_INFINITE);
    chDbgAssert(status == MSG_OK, "ibqGetFullBufferTimeout");
    // doing something with readWriteQueue.ptr
    ibqReleaseEmptyBuffer(&readWriteQueue);
Alexandre
alex31
Re: hal_buffer_queue : how to use it
Post by alex31 »
Hum, was my fault, did not notice that the input_buffer_queue store private field (size) in buffer, and that one should reserve NEED_SIZE + sizeof size_t
All works now, sorry for disturbance.
Alexandre
